Author: Subject: How do you calculate shock absorber length?
aerosam
posted on 15/4/09 at 07:11 PM Reply With Quote
Hi Guys,
I need to buy the rear shocks for my bmwcost but how do i work out what length shocks I need to give me a useable range of ride height?
For those who don't know, I'm using a +4 chassis with the BMW E34 axle carrier and semi trailing arms. The shockers are going to be mounted between the trailing arms and normal mounting points on the chassis.
I haven't yet welded on the mounting brackets for the shocks so all figures below are innacurate but fairly close, I just need to know how to work it out.
With a trailing arm at it's lowest point of travel the distance between mounting hole centres is 17" at it's highest point it's 10" ( but i'm not sure I want the wheel to travel that far)
Help! This is the stuff I simply don't understand.
Thanks,
Sam
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
MikeCapon
posted on 15/4/09 at 08:36 PM Reply With Quote
Simples! Drop the wheels down to the lowest point you want (maximum droop) and measure between mounting points. This is your open length.
Then lift the wheels to the highest point you want (maximum bump) and measure again between mounting points. Full droop measurement minus full bump measurement equals stroke.
Most locosts seem to have a total wheel movement of around 4" or 100mm. What have you got at the front?
If you need more help then I'll be back on tomorrow.
Mike
aerosam
posted on 15/4/09 at 09:44 PM Reply With Quote
Hi Mike,
The only thing that worries me is might I be at risk of bottoming out the rear suspension if the trailing arms have more movement than the shocks will allow?
the front is Haynes Roadster so I'll be using the same shocks it uses. The wishbone mounting points are almost identical the the locost (3mm further apart on the lower wishbone i think).
Thanks!
Sam
procomp
posted on 16/4/09 at 07:14 AM Reply With Quote
Hi
Regarding your trailing arms. They will have quite a lot of travel due to there not being any joints that can lock out / run out of travel. But in reality as a guide virtually all cars running rear trailing arms run with a 13" open length. This generally gives 3.5" of travel which is more than enough.
At the rear put some packers under the car to get the desired ride height you wish to attain with driver on board with the wheels/tyres on the ground.
Then raise the chassis 1.5" and measure this as Mike says ^^. This gives you the open length. This is the dimension that the damper suppliers are quoting when referring to the length of a damper.
Cheers Matt
