SALAD
posted on 16/4/09 at 08:01 PM |
Megajolt/squirt Laptop Requirements?
After a while searching, I couldn't find the answer so.....
What are the basic laptop requirements for running megajolt / squirt?
Ie: ports/ connectors, memory etc
I remember it being mentioned sometime ago.....by someone.....somewhere......
r1_pete
posted on 16/4/09 at 08:05 PM |
I use an old IBM T23, 1.2Ghz, 256Mb memory, 1 x serial port (the iportant bit), XP sp2, and it eats MJ.
Might have a similar machine for sale in the near future....
SALAD
posted on 16/4/09 at 08:18 PM |
Thanks chaps
brianthemagical
posted on 16/4/09 at 08:30 PM |
Battery life can be a consideration, kinda pointless if you need to charge your laptop after 45mins of use, especially when an inverter makes the car
voltage drop.
Don't rule out USB, if you've already got a laptop, nearly anything will work.
SALAD
posted on 16/4/09 at 08:37 PM |
I didn't want to use this laptop really.
I was thinking an inexpensive little thing purely used for the car....
Avoneer
posted on 16/4/09 at 09:08 PM |
Ex-military Panasonic CF-27.
Vibration, splash and drop proof.
1 x USB and 1 x Serial port.
On ebay for around £65.
Pat...
Andybarbet
posted on 16/4/09 at 09:56 PM |
If your laptop has no serial port, could you use a usb/serial adaptor ???
Just looking at the minibook in the for sale section and wondering if that would be useable for mega squirt ??
Havent the money at the mo but something to look into in the future
[Edited on 16/4/09 by Andybarbet]
brianthemagical
posted on 16/4/09 at 10:03 PM |
Some usb converters do work, that's how i use mine, some don't though.
mad4x4
posted on 17/4/09 at 06:16 AM |
someone suggested searching for "Faulty Laptop" on Flea Bay. Few folks have got good deal for £20 quid etc.
Depends if you willing to re-install XP etc.... As often that is most of the problem.
Also Do you nned tp worry about battery life, if it is just for in the garage changing the ignition settings. My just plug mine in.
Scot's do it better in Kilts.
Avoneer
posted on 26/4/09 at 09:19 AM |
Another reason for an ex-military Panasonic CF-27 - works of the cig lighter as well as battery.
Pat...
