wam builder
posted on 18/4/09 at 09:06 PM |
gsxr 1000 exhaust power valve
Is anyone else running a k6 1000 without the valve in the bec system?
I intend to run it merely by not connecting the wires! should these be by passed in some way
yorkshire-engines
posted on 18/4/09 at 09:40 PM |
cut the black/brown wire running to the ecu
this will remove the evac valve from the system if you fit the valve you will still get the fault code on dash
wam builder
posted on 18/4/09 at 11:19 PM |
Gsxr epv
Magic, someone who has something i'm looking for when I need it, not when i've found it. You have u2u Malc.
