Author: Subject: Iva Bias bar your opinions pls?
big_wasa
posted on 19/4/09 at 07:22 PM Reply With Quote
Ive made a sort of non adjustable bias bar for the iva so that I dont have to weld mine up.
Ive set it to about 80% front. But if its wrong I can just cut two new grooves for the cir-clips and move the bearing along. You wont be able to see that as it sits in the pedal bush
When set I will fit a couple of roll pins.
What do you think ? Will it pass if it gives the correct braking.
cheers
[Edited on 19/4/09 by big_wasa]
dinosaurjuice
posted on 19/4/09 at 07:24 PM Reply With Quote
i dont see that as being adjustable. therefore i think it wil pass.
edit: nicely made BTW. theyll be a waiting list to borrow that for iva
[Edited on 19/4/09 by dinosaurjuice]
blakep82
posted on 19/4/09 at 07:34 PM Reply With Quote
i want one
________________________
robinj66
posted on 19/4/09 at 10:23 PM Reply With Quote
It does look a lovely piece of kit but, according to the article in the latest Complete Kit Car, the IVA want a bioas bar to be "permanently rendered unadjustable".
Roll pins were acceptable for SVA but apparantly will not be good enough for IVA
posted on 20/4/09 at 08:18 AM Reply With Quote
Since big_wasa's design is inherently non-adjustable, that should not be a problem.
Mix
posted on 20/4/09 at 05:35 PM Reply With Quote
Hi
I think the theory is good 'in principle' however I would be concerned that drilling the bias bar where you have significantly reduces it's strength. In my opinion its better to secure at a point outside of the clevis. Otherwise an interesting exercise, look forward to news as to how it's received at IVA.
Regards Mick
big_wasa
posted on 20/4/09 at 08:41 PM Reply With Quote
It only needs to last for a short time
Its a 4mm pin through a 7/16 bar.
Any one want to do the maths for me ?
Bob C
posted on 22/4/09 at 11:55 AM Reply With Quote
You don't have a problem, there is very little stress of the bar where there's a hole through it. Your stress raisers are the circlip grooves..... keep them as shallow as you dare....
posted on 22/4/09 at 11:14 PM Reply With Quote
Always thought they were a bit of a poor design, the threaded sections don't help either. Then again I guess the bars are plenty strong enough since I've not heard/read of any failures.
One of the previous owners of my Stiker thought that a piece of M6 stud would make an effective bias bar, I had a shock when I removed the pedal box cover and found the tiny, banana shaped bar. The most worrying thing of all is that it was a track car and had passed scrutineering many times judging from all the tickets I found stuck to the transmission tunnel.
I'll take a pic when I remember, a kind of "how not to make a bias pedal box"
