Author: Subject: Tapping M10 hole
chrisg
posted on 22/4/09 at 02:39 PM Reply With Quote
Tapping M10 hole
I need to fix my engine in place, it has M10 x 1.25 fine threads into an aluminium crankcase, but I don't have the correct bolts.
Would it be ok to tap these out to standard pitch M10?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Humbug
posted on 22/4/09 at 02:46 PM Reply With Quote
I would have thought it would strip or cross the threads, making it less effective.
tegwin
posted on 22/4/09 at 02:56 PM Reply With Quote
NO... dont do that! Course threads in aluminium dont work at the best of times hence why most are fine....
Trying to switch between fine and course would just FUBAR the hole!
www.verticalhorizonsmedia.tv
chrisg
posted on 22/4/09 at 03:00 PM Reply With Quote
Message received and understood!
Thanks chaps
Chris
mad-butcher
posted on 22/4/09 at 03:06 PM Reply With Quote
try these chris http://stores.shop.ebay.co.uk/WVS-FASTENERS_METRIC-FINE_W0QQ_fsubZ13QQ_sidZ124709800QQ_trksidZp4634Q2ec0Q2em322
chrisg
posted on 22/4/09 at 03:18 PM Reply With Quote
Cheers Tony
posted on 22/4/09 at 03:26 PM Reply With Quote
you sure about that? I thought aluminium and cast iron both use course threads?
e.g. on ford crossflow, head and alloy inlet manifold use UNC.
.... but then I don't know for sure, it is google time I guess....
AdamR
posted on 22/4/09 at 04:10 PM Reply With Quote
Agreed. Everything on a Rover V8 (aluminium block) is UNC.
mad-butcher
posted on 22/4/09 at 04:25 PM Reply With Quote
japanese
minitici
posted on 22/4/09 at 04:38 PM Reply With Quote
You could always fit helicoil or re-coil wire inserts and convert to 'standard' metric pitch.
Jimbob
posted on 22/4/09 at 05:03 PM Reply With Quote
Just buy the correct bolts!
They wont be expensive and its the right way to do it
chrisg
posted on 22/4/09 at 05:29 PM Reply With Quote
BUY!!!!
I nearly choked on me whippet!
Are you a REAL Yorkshireman or a foreigner?
(Actually that's what I've done, via Tony's link It was just an idea to save some time)
Chris
posted on 22/4/09 at 05:45 PM Reply With Quote
Soft metal should have coarse threads - stuff like aluminium is too weak to support fine threads in the way steel can.
It depends on your definition of 'fine' of course!
chrisg
posted on 22/4/09 at 06:58 PM Reply With Quote
That being the case, I wonder why Honda went for fine threads?
Chris
richmars
posted on 22/4/09 at 07:05 PM Reply With Quote
It's no the finest M10, you can also get M10x1.0
So maybe x1.25 is a good comprimise.
posted on 22/4/09 at 07:17 PM Reply With Quote
I have taps and dies in my toolbox for 1/2" x 40tpi - that's fine!
(It's a model engineering thread, easy to set up for thread-cutting in an imperial lathe)
