Author: Subject: getting oil stains out of clothes
smart51
posted on 22/4/09 at 07:48 PM Reply With Quote
Oops! I've done it again. Done some work on my car without getting changed first. This time I thought, I'll be fine I won't do anything dirty, I'll just undo the first few bolts and come back later. then I dropped the spanner in the pan of oil on the floor under the car.
So, I've tried soaking it in biological detergent overnight and washing it in the machine. The oil has faded but not gone. How do you get engine oil out of a shirt?
[Edited on 22-4-2009 by smart51]
blakep82
posted on 22/4/09 at 07:52 PM Reply With Quote
shampoo is pretty good, but i think you really need to do it while the oil is still wet.
shampoo's really just a degreaser
________________________
Burn it.
posted on 22/4/09 at 07:59 PM Reply With Quote
Brake Cleaner - gets out Grease and Oil.
Basically is Trichloroethane (SP) degreaser but VERY strong! Use in open spaces only... I've been told it is the same as DRY CLEANING FLUID.
[Edited on 22-4-09 by Hellfire]
speedyxjs
posted on 22/4/09 at 08:01 PM Reply With Quote
Brake cleaner is like cillit bang for mechanics
owelly
posted on 22/4/09 at 08:03 PM Reply With Quote
WD40 to get the stain out and then Fairy Liquid to get rid of the WD40...
http://www.ppcmag.co.uk
snapper
posted on 22/4/09 at 08:13 PM Reply With Quote
It wont be oil stains you worry about when its built and your driving it it'll be the other sort of stains
I eat to survive
I drink to forget
posted on 22/4/09 at 08:18 PM Reply With Quote
I thought that Trich is now banned? The newer brake cleaners don't seem to be as good as the older ones were but still worth a try. I have used brake cleaner to remove grease stains from carpets with good results.
posted on 22/4/09 at 08:29 PM Reply With Quote
You can still get it...
I think they have changed from Trichloroethylene to Trichloroethane....
I used to have top do COSHH on them - though you're right the new one's are not as good as the old. Course I could be wrong cos it's all from my (OLD) memory!
thunderace
posted on 22/4/09 at 08:40 PM Reply With Quote
Swarfega
RUB IT IN AND WASH IT OUT THE NEXT DAY IT WORKS AND ITS CHEEP.
thorpey182
posted on 22/4/09 at 08:50 PM Reply With Quote
i'll second the WD-40 technique, took a while but managed to get the vast majority of oil out.
ashg
posted on 22/4/09 at 09:49 PM Reply With Quote
brake cleaner every time. if that dont shift it use paint thinners
[Edited on 22/4/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
James
posted on 22/4/09 at 10:28 PM Reply With Quote
Originally posted by thunderace
Swarfega
Seconded! Works well, expecially the 'gritted' stuff if you work it in!
James
posted on 23/4/09 at 07:52 AM Reply With Quote
Swarfega for me too. then some washing up liquid to dilute it a bit more.
Danozeman
posted on 23/4/09 at 08:04 AM Reply With Quote
Swarfega for me too. works well. I always do it to my work clothes.
Dan
posted on 23/4/09 at 09:14 AM Reply With Quote
I've also used the WD40 trick to good effect.
Lightning
posted on 23/4/09 at 12:03 PM Reply With Quote
What about on leather. I got some on the back seat on my CRV when getting parts, its only 1 year old
