Numb nuts
posted on 26/4/09 at 08:13 PM |
Tyre pressures
Hi all.
In relation to Davey D's 'Self Centering' topic, there was a lot of talk about tyre pressures.
What are the recommended tyre pressures for a locost 7 type?
I am running mine at 16psi all round.
posted on 26/4/09 at 08:19 PM |
Running 18psi all round on mine
marshall
18 psi will be ok if the tyre is a 195 size
omega0684
posted on 26/4/09 at 08:22 PM |
i run 15 all round but think this is a bit low so im going to put mine up to 18-20 psi
Numb nuts
posted on 26/4/09 at 08:25 PM |
They are 195/50-15's
stuart_g
posted on 26/4/09 at 08:34 PM |
18psi works for me.
clairetoo
I run 18 psi all round (195/50 15's on a 685 kg Fury)
Its cuz I is blond , innit
Claire xx
Will weld for food......
iain b
posted on 26/4/09 at 08:36 PM |
mnr vortx on 195 /205 rear 161b runs great
Ninehigh
posted on 26/4/09 at 10:36 PM |
Just as a thought is there any kind of formula to work it out? Sometimes my tintop tyres look low but then when I check them they're exactly at
the pressure the book says
clairetoo
posted on 27/4/09 at 06:01 AM |
quote: Originally posted by Ninehigh
Sometimes my tintop tyres look low but then when I check them they're exactly at the pressure the book says
Where is the valve when you check them ? They will only be low at the bottom , so you may need to rotate them to get a better reading
Claire xx
Richard Quinn
posted on 27/4/09 at 06:15 AM |
I always thought that they were higher at the bottom because that's the bit being squashed so there's more pressure.
Ninehigh
posted on 3/5/09 at 05:04 PM |
I make sure it's in the middle so I get an average
