TimC
posted on 30/4/09 at 10:31 AM |
OT: Prototype / Display Model Manufacture
As part of my MBA business plan, I'd like to have a physical model of the proposed product. It's nothing fancy. The actual thing would
just look like an injection moulded box. I need to source or make something cheaply however that looks like the real thing. My sole idea thus far is
to carve it out of polystyrene and then cover in resin and paint. Anyone got any better thoughts?
Ta
tegwin
posted on 30/4/09 at 10:35 AM |
If you just need an injection molded box.... cant you buy a cable enclosure.... RS sell loads of different sized ones mainly thermoplastic..... Or
use a socket putress box if you need a thermoset....
www.verticalhorizonsmedia.tv
designer
If it is to look like an injection moulded box, why not use one, Maplins?
TimC
posted on 30/4/09 at 10:46 AM |
Sorry - I didn't make myself clear. The shape and size of the box is pretty critical to the product (ergonomic) and therefore unique.
Keep the suggestions coming...
Ta
stevebubs
posted on 30/4/09 at 10:49 AM |
plaster of paris?
pewe
posted on 30/4/09 at 11:08 AM |
You can buy high density expanded Poly styrene which is used for modelling.
Bought some years ago for an exhibition display from IIRC Sheffield Insulations. But maybe Hobbystore for smaller quantities.
Also made a hot-wire cutter by using a battery charger, copper tube for the arm fixed into a base-board and fuse wire for the cutting wire (obviously
needs to glow red to heat sufficiently).
Alternatively the poly can be cut, sanded and painted quite easily.
Sheffield Ins. weren't cheap but hey if your future career relies on it got to be worth it.
If you want a sketch of the cutter U2U me your email.
HTH.
Cheers, Pewe ![](/images//smilies/cool.gif)
mccsp
posted on 30/4/09 at 11:11 AM |
Rapid Prototype?
Some Universities (Loughborough as an example). Have RP research facilities and can sometimes fit in additional work at surprisinly low cost. Looks
very professional and can be finished quite nicely.
If it is small enough can fit in with another job for minimal increase in cost. Would require 3D modelling though.
chrisg
posted on 30/4/09 at 11:21 AM |
I've done some stuff in laminated MDF, for things like rounded edges it's much easier to get a consistant surface using a router than
trying to sand foam.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 30/4/09 at 11:26 AM |
clay - like concept cars?
The rapid prototype suggestion is a good one too especially if you can get the object modelled in 3D. We use it at work for prototyping injection
moulded parts prior to actually making a mould tool. finishes really well and can be painted to look like the real thing.
blakep82
posted on 30/4/09 at 11:30 AM |
i think, if you used polystyrene, then put resin over it, i think the polystyrene collapsed and melts.
clay might be your best, unless you fancy going into making a fibreglass mould from the clay, and then make a fibreglass model?
________________________
Hammerhead
posted on 30/4/09 at 12:06 PM |
bolsa wood is good for models.
hughpinder
posted on 30/4/09 at 12:12 PM |
Carve it out of a candle (if you go wrong just melt a bit back in), - remember a pouting funnel. Cover in plaster of paris - a couple of layers, turn
upside down when dry and melt out in a warm oven into a baking tray - recast as candles!. Castable PU or resin, and crack off the plaster.
Hugh
tegwin
posted on 30/4/09 at 12:40 PM |
Some of the education companies sell a rapid prototyping stuff for making ergonomic products..
Its like wax but melts at a low temp... you can mould it with your hands... let it cool and it goes pretty hard.... you could then machine the centre
out with a vertial mill... or a drill and chissel if tools allow...
The kids use it to make mobile phones and MP3 players etc for graphic design work... some of them are fantastic!
Fred W B
posted on 1/5/09 at 07:31 PM |
My sole idea thus far is to carve it out of polystyrene and then cover in resin and paint. Anyone got any better thoughts?
If its got large flat planes with straight edges I reckon MDF planks screwed together will be easier. Use plaster filler to add raidiuses and cover
with a layer of GRP to blend it all together. Skim with filler and sand to get the surface smooth
Fred W B
iank
posted on 1/5/09 at 08:33 PM |
If it's a complex shape (something like a fighter joystick) then mould in clay and then get one of the latex moulding kits and cast one in
resin.
If it's a flat edges then wood or perspex would be best sprayed up white (seems to be a traditional colour for models like that).
Anonymous
