Author: Subject: rear hub spacers and handbrake
westclad
posted on 12/5/09 at 08:31 PM Reply With Quote
hi again
So many questions
has any body spaced the hubs away from the hub carriers on the rear of the car as or have you fitted them directly against the carrier, as the drive shaft cv joints compress ok, not sure if this is going to put extra stress on the joints.
Also what are people using as a linkage between the handbrake lever and rear cable.
Thanks again
Ade
stevegough
posted on 12/5/09 at 08:53 PM Reply With Quote
have you got the build manual?
Shows some photos of how to do it. (haven't got that far myself, yet).
reproduced them here for you:
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
tj4ord
posted on 12/5/09 at 09:33 PM Reply With Quote
hey! i'm fitting drums to mine and made up some spacers to bring the hub away from the carrier think it was about 5-6mm.
the handbrake on the otherhand will hopefully be fitting this weekend so will put photo's up then.
