Author: Subject: Duratec MPG
Breaker
posted on 14/5/09 at 04:50 PM Reply With Quote
Duratec MPG
A standard duratec ( 2007-... ;145 hp) with air mass meter uses around 8 litres of fuel per 100 km (in a normal production car)
2 questions:
What is the fuel consumption of a duratec with throttle bodies in a 600kg kit car ?
And how does your engine computer knows how much fuel to inject if you are running on throttle bodies (=> no air mass meter) ?
omega0684
posted on 14/5/09 at 04:54 PM Reply With Quote
you could run an inlet plenum and have the mass air flow meter on the inlet?
snapper
posted on 14/5/09 at 04:56 PM Reply With Quote
The standard Duratec engine computer will not work with throttle bodies, infact the standard Duratec ECU is unlikelly to work at all because of the built in security features which need things like the dash clocks, ABS, door locks etc.
The Duratec however will work very well with an after market ECU
I eat to survive
I drink to forget
matt_claydon
posted on 14/5/09 at 04:58 PM Reply With Quote
You need an aftermarket ECU which will calculate fuel based on manifold pressure and/or throttle position instead of the air mass meter.
snapper
posted on 14/5/09 at 04:59 PM Reply With Quote
Fuel consumption in a light car should be better however in practice the gearing will be much lower and you will spend most of the time higher up the rev range with you foot hard on the go pedal and a stupid grin on your face
I eat to survive
I drink to forget
posted on 14/5/09 at 05:05 PM Reply With Quote
Also aerodynamics play a big role, at motorway speeds in a Seven you will never achieve the mileage that modern tintops get.
diyer
posted on 14/5/09 at 05:27 PM Reply With Quote
Didn't think a Duratec uses a MAF!!
Simon
Hug a Hoodie!
flak monkey
posted on 14/5/09 at 05:47 PM Reply With Quote
Simon
I think some do, the focus one does AFAIK. Think the mondeo is TPS and MAP. Could be wrong though....
Sera
http://www.motosera.com
grazzledazzle
posted on 14/5/09 at 05:55 PM Reply With Quote
I average around 30 mpg in my focus 2.0 duratec. It ain't that good on fuel. I have had the trip at 14mpg on a spirited drive....
Mpg is irrelevant in a kit car in my opinion.
Breaker
posted on 14/5/09 at 10:17 PM Reply With Quote
Simon
I know they have a MAF + ETB in Volvo's.
There they call the engine "NI4" instead of "Duratec".
