*davies144*
posted on 17/5/09 at 09:32 AM |
pinto tappets
hi is best resetting the tappets when the engine is warm or cold? cheers ben
omega0684
posted on 17/5/09 at 09:39 AM |
always when cold and ideally with the head on the bench
jpindy3
posted on 17/5/09 at 09:40 AM |
i did mine when it was worm i think.
it runs fine
he is right,its in the haynes book,
metal contracts,so if you do it worm when cold you will have big gap,so do it cold and dont lisson to me!!!!
[Edited on 17/5/09 by jpindy3]
omega0684
posted on 17/5/09 at 09:41 AM |
quote: Originally posted by jpindy3
i did mine when it was warm i think.
it runs fine
then you didn't read the haynes manual
[Edited on 17/5/09 by omega0684]
Bigheppy
posted on 17/5/09 at 09:46 AM |
If I put my head on my bench I cant reach the car to adjust the tappets ![](/images//smilies/bigsmile.gif)
*davies144*
great stuff thanks, also it stutters a bit when giving it beans , is this probably due to the car having not been set up very well, i only bought it
fri nite so havnt really had a proper look yet.
omega0684
posted on 17/5/09 at 10:06 AM |
if its stuttering under acceleration then its more than likely a fueling problem, from experience with my megasquirt its probably running very lean
under acceleration so either needs the fuel cranking up on the fuel map (if you haev that ability) or remapping
*davies144*
posted on 17/5/09 at 10:09 AM |
ok, wel its jus running on the standard dizzy on a webber carb? so do i need to adjust the mixture you think?
omega0684
posted on 17/5/09 at 10:22 AM |
what is the car like under other driving conditions? is it struggling at idle ? or popping when your driving along? have you checked whether the
needles in the webers are blocked. it might need the fuel pressure increasing slightly, do you have a fuel pressure gauge or checked the fuel
pressure?
*davies144*
posted on 17/5/09 at 10:30 AM |
its not to bad, well the tappets need adjusting but im doing that today, i havnt i dont really no alot about carbs unfortuantely. but a far more
experianced friend of mine is driving up to mine today so we'll have a look, Thanks for the advice, by the way looking at you r build pics did
you buy the manifold for bike carbs or make it it looks real smart piece of kit! ben
omega0684
posted on 17/5/09 at 10:37 AM |
dave at bogg bros made my manifold for me, everything else i did myself
