Author: Subject: st170 cam belt tension.
mr zefect
posted on 17/5/09 at 06:09 PM Reply With Quote
Does any one know how to tension a cam belt on a st170 engine i have tried to tension it up but when tensioner bolt up it still has a sprung movement is this right and arrow thingy moves i am only used to silver top engines that have a different set up any help would be apreciated thanks.
r1_pete
posted on 17/5/09 at 06:19 PM Reply With Quote
You position the ponter in the centre of the square window, then nip the pivot bolt up. Turn the engine over a couple of times, then recheck the pointer, if still in the middle of the suare window, torque up the pivot, if not repeat, job jobbed.
Pete.
[Edited on 17/5/09 by r1_pete]
r1_pete
posted on 17/5/09 at 06:27 PM Reply With Quote
Sorry forgot to mention you use an allen key to turn the tensioner to move the pointer.
mr zefect
posted on 17/5/09 at 06:40 PM Reply With Quote
Thanks for that help i wasnt sure if it was right it seemed floppy to me.
