*davies144*
posted on 24/5/09 at 03:04 PM |
fire damaged wiring
hi, this is what i need to replace ! main plugs are the ignition module, coil plugs and water temp sensor, wonderd if there is anyone nearby willing
to help out with the electrics?? would be very much appreciated!!
this is the mess >>>>>
*davies144*
posted on 24/5/09 at 03:05 PM |
pic
*davies144*
posted on 24/5/09 at 03:06 PM |
pic
Wheels244
posted on 24/5/09 at 05:19 PM |
If you're willing to pay I can recommend Gary from Autosparks - the man is a god when it comes to autoelectrics - he wired mine from start to
finish in a day - no fault codes and the price wasn't bad either.
Let me know if you want his number.
Obviously auto electrics aren't my thing otherwise I would have come down for a blast to help.
As it happens I was on Easingwold bypass this morning as part of a 160mile blast around
*davies144*
posted on 24/5/09 at 05:58 PM |
yeh if you could send me his number that would be good! was it a good blat? went to clifton moor and must of seen four 7's on the way there and
back i was so jealous!
Wheels244
posted on 24/5/09 at 06:48 PM |
U2U sent
Yes, had a great blast round - I took a mate out for the 1st time - he now wants to buy one
wilkingj
posted on 24/5/09 at 10:01 PM |
What about a scrapyard / breakers for the plugs / sockets?
What engine / electrics?
Just a thought.
Best Regards
Geoff
http://www.v8viento.co.uk
*davies144*
posted on 25/5/09 at 10:15 AM |
hi yeh i think il be taking a day off work to search round the local scrappers to see what i can find, im guesing its part of the siera loom, and its
a 1.6 pinto
Gazeddy
posted on 25/5/09 at 05:43 PM |
the post connectors for the coil are the same as blue female bullet connectors from motor factors i think the water temp will be too but it may be a
blue femal spade end
wilkingj
posted on 25/5/09 at 06:30 PM |
That looks like the ignition electronics module. (connects to the Dizzy).
This could be harder to find.
Maybe just the wiring is melted, and the module is OK, but you will need a new plug and wiring.
Worst case is convert to megajolt!
One bit looks like the capacitor off the alternator, easy to get.
Cant recognie the other bits.,
Still its not a disaster, just a an inconvenience.
Best Regards
Geoff
