Author: Subject: best way to fit sump gasket
omega0684
posted on 25/5/09 at 12:49 PM Reply With Quote
i have the pinto block upside down at the moment, would it be better to stick the gasket to the block and then stick the sump to the gasket or stick the gasket to the sump and then to the block?
nitram38
posted on 25/5/09 at 12:52 PM Reply With Quote
Cork gasket with cut outs on the sump edge?
Blue Hylomar on sump, stick gasket on sump, blue hylomar on block, then put the sump/gasket on.......
Put all the bolts in, check and then tighten in cross diagonal sequence.
CaptainJosh
posted on 25/5/09 at 01:14 PM Reply With Quote
Thumbs up for Blue Hylomar and don't get the silicon stuff that looks the same.
Jon Ison
posted on 25/5/09 at 01:52 PM Reply With Quote
Old school here, smear of grease on both surfaces to make for easy future removal, job done.
ReMan
posted on 25/5/09 at 07:39 PM Reply With Quote
|Grease for me too if it's a cork gasket
