omega0684
posted on 28/5/09 at 12:38 PM |
rad mounting
do rads have to be mounted on rubber bushes or not, or is it recommended that you do?
blakep82
posted on 28/5/09 at 12:39 PM |
i would. reduced vibration, less risk of fatigue fractures etc
________________________
clairetoo
posted on 28/5/09 at 02:15 PM |
Ive never rubber mounted a radiator - never had a problem either
Its cuz I is blond , innit
Claire xx
Will weld for food......
tomgregory2000
posted on 28/5/09 at 02:26 PM |
na i dont, mine is in a steel frame
posted on 28/5/09 at 02:38 PM |
Mine is mounted solid, rad on the zook I'm stripping for the 4x4 was solid mounted to the chassis as well.
posted on 28/5/09 at 04:19 PM |
my 2p worth; not come across a rubber mounted rad.
land rovers are bolted to bodywork and thye get subjected to more shakes and jolts than a road only car - not heard of any problems arising.
blakep82
posted on 28/5/09 at 04:41 PM |
ah, there you go then
all my BMW radiators have been rubber mounted btw
chrisg
posted on 28/5/09 at 04:47 PM |
That's funny, my experience is completely the opposite.......All the tintops I've had have had rubber mountings as did my Locost and the
Roadster, In fact I've mounted the rad on my new car today - with rubber.
I suppose that shows that it doesn't matter much?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 28/5/09 at 06:39 PM |
I agree, all modern production cars I have seen have rubber mountings for the radiator. Often they are simple rubber "grommets" in the
front cross member and slam panel that plastic posts on the radiator end tanks just press in to.
