*davies144*
posted on 30/5/09 at 11:06 AM |
simple engine wiring diagram????
hi, has anyone got a simple wiring diagram for a 1.6 ohc pinto engine? because i want to get my fire damaged car back on the road quick!!!!! I want to
make the most of this weather!!!!! do i need an ignition module for it to run? itsrunning on a points dizzy by the way.
cheers ben
mookaloid
posted on 30/5/09 at 11:24 AM |
A points dizzy doesn't need an ignition module to run - you just need a coil and the dizzy.
Someone should be along with a diagram soon but it's pretty easy.
mark
mookaloid
posted on 30/5/09 at 11:28 AM |
how about this:
The only difference is that this is for a single cylinder engine so the HT lead goes to the dizzy first then the plugs but otherwise the principle is
the same. the ignition switch goes in between the battery and the coil
[Edited on 30/5/09 by mookaloid]
omega 24 v6
posted on 30/5/09 at 11:38 AM |
Feck me Mookaloid that's an old diagram.
+ve earth ???????? must be the system used on the ark LOL.
*davies144*
posted on 30/5/09 at 11:39 AM |
Thanks for the help so far I'll keep you posted
rotax78
The diagram above is for a positive earth vehicle, not the usual negative earth cars of today, but shouldn't be too hard to figure that out.
Regards Simon
[Edited on 30/5/09 by rotax78]
omega 24 v6
posted on 30/5/09 at 11:46 AM |
Try this site plenty of info on it.
westfield world
mookaloid
posted on 30/5/09 at 11:49 AM |
Sh*t - I never even looked that closely at it - usual disclaimer about senile dementia creeping in applies.
omega 24 v6
posted on 30/5/09 at 11:55 AM |
Ah Old age it creeps up on you.
Basically swap the + and - around and it's all the same diagram anyways 9 with an ign switch in line of course).
tomblyth
posted on 30/5/09 at 06:18 PM |
I love the way this sited changes sh*t to poo when you post!
