Author: Subject: Airflow through radiator?
MautoK
posted on 30/5/09 at 05:03 PM Reply With Quote
What do you have as a grille in your nosecone?
I fitted pierced stainless sheet (1/4 inch dia holes and about 57% hole overall) and an 'MK' stainless steel logo.
Front, closer
Front, closer
Is it likely/possible/unlikely that this is impeding the airflow sufficiently to have caused my overheating grief? I'm thinking turbulent flow. Any fluid dynamicists out there?
Also, I have no vents in the bonnet or sidepanels but the gearbox/prop tunnel is open as is the bottom of the engine bay - so it should be well capable of losing the hot air.
Anyone have observations or experience on airflow issues?
I've cleaned up the block and head faces and there's no damage evident; used a suction doofah to get the water and a bit of sludge out of the water jacket and it's cleaner than many I've seen. So tomorrow the head goes back on...
Before getting the last of the water out, I twidded the water pump pulley and could see disturbance to the water, so assume that the pump is OK. Anyway it's only done 40-50 miles since I refitted it, and if it had been compromised I'd have fitted a new one...
Thanks guys,
John.
posted on 30/5/09 at 05:31 PM Reply With Quote
I cut two holes in the rear of my nose cone and three in the rear of the bonnet which dropped the coolant temperature and the under bonnet temperature considerably
MautoK
posted on 30/5/09 at 05:37 PM Reply With Quote
Aha! Interesting, Mr Rusty. How big holes?
posted on 30/5/09 at 05:45 PM Reply With Quote
Approx six in long and two wide . Will try to post some pictures tomorrow if I can find the camara. Water Wetter will drop the coolant temperature , worth a try?
omega0684
posted on 30/5/09 at 07:18 PM Reply With Quote
have you posted twice tonight, get rid of the mesh and keep the mk grill
scoop
posted on 30/5/09 at 07:41 PM Reply With Quote
There should be plenty getting through there. You dont want your red getting holed by a stone or something.
Just looked at your new rad pics. Its not still plumbed like that at the header tank end is it?
MautoK
posted on 30/5/09 at 07:44 PM Reply With Quote
Yes, Alex, this thread and a similar one in 'Bodywork & Exterior'.
John.
MautoK
posted on 30/5/09 at 07:50 PM Reply With Quote
I'm concerned that the flow through the holes is so turbulent that it throttles the flow, and/or giving rise to turbulent flow through the rad itself (where you ideally need clean laminar flow).
Do you mean the inverted bottle or the pipework, scoop?
MautoK
posted on 30/5/09 at 07:53 PM Reply With Quote
Did you fit the vents because you were actually suffering overheating or to reduce the likelihood of it happening?
scoop
posted on 30/5/09 at 07:55 PM Reply With Quote
The pipe work. You seem to have both pipes feeding into one from the over head shot.
MautoK
posted on 30/5/09 at 08:04 PM Reply With Quote
See what you mean!
Header, overflow, fusebox
The bigger one appearing from the lower right corner tees into the bottom hose (rad out to w/pump); the little one connects the header tank's overflow to the bleed port at the top of the Polo rad.
bimbleuk
posted on 30/5/09 at 08:05 PM Reply With Quote
If you want to get technical then buy a second hand Magnehelic pressure differential gauge and measure the presure in front and behind the radiator. Having lower pressure behind the radiator is more significant than the flow in to the nose cone. In practise you only need about 1/4 the frontal arear of the radiator (or intercooler) to feed sufficient air. Another tip is to block the gaps around the side of the radiator or fit a cowling to trap air in front.
The air under the car and down the tunnel is quite turbelent. Side exit vents do appear to be the best solution, preferable quite large ones. As mentioned previously this also lowers the under bonnet temps quite significantly.
I guess my car is quite a good example as I have an intercooler covering most of the front of the radiator. I use a small Polo rad and an oil cooler behind that for my Rotrex supercharger oil. I use a Sierra oil/water cooler as well so my coolant is doing quite a lot of work! So far no issues with cooling my engine on road and track.
[Edited on 30-5-09 by bimbleuk]
scoop
posted on 30/5/09 at 08:08 PM Reply With Quote
Ok mate. You have u2u
MautoK
posted on 30/5/09 at 08:40 PM Reply With Quote
That's one full engine bay you've got there!
If you're dissipating the heat from that lot through a Polo rad then I should be having trouble getting a bog standard 2L pinto warm!
Good idea on the deltaP gauge - might make a locost one from plastic tubes.
John.
C10CoryM
posted on 30/5/09 at 09:09 PM Reply With Quote
bimbleuk has the right idea.
Radiator exhaust is more important than intake. You need to have a lower pressure area behind the rad. Sealing the radiator so that all air has to pass through the core is also VERY important.
Your grille is not the problem.
"Our watchword evermore shall be: The Maple Leaf Forever!"
MautoK
posted on 30/5/09 at 09:31 PM Reply With Quote
C10CoryM:
Sounds as if you've found out the hard way!
My situation is possibly not helped by having foam rubber strip effectively sealing the trailing edge of the bonnet to the scuttle.
I feel a run with the bonnet off beckoning...!
John.
posted on 31/5/09 at 07:40 AM Reply With Quote
John , I put the vent holes in place as a precaution but did notice a large drop on the temperature gauge after doing so.
