posted on 1/6/09 at 03:21 PM |
Do your tools ever hide from you?
Am I alone here or do other peoples tolls sometimes choose to hide and then reappear...?
Spent forever the other night turfing everything upside down in the garage looking for the 8mm hex bit I know I have - could I find it - could I chuff
as like
Off to Halfords, buy another one, get home use the new one once, job done. Open tool draw to put the new one away.......there's my old one sat
there bold as a lump of steel
Like I say is this just me...?
smart51
posted on 1/6/09 at 03:23 PM |
yes, especially with allen keys. I have 3 sets and still can never find the one I want.
mookaloid
posted on 1/6/09 at 03:24 PM |
You are not alone - it gets worse as you get older too
Dangle_kt
posted on 1/6/09 at 03:25 PM |
I had a socket wrench that I was sure an ebayer had robbed. He came to the house, but couldnt fit the item in his car, so I lent him my socket set to
take it apart, and since then I couldn't find it.
About 3 days passed, and i worked up the courage to message him through ebay, asking for it back.
I found it on the passenger seat of the kit car.
RED FACE!
Guinness
Think of it as the Locost version of hide and seek!
Mike
blakep82
posted on 1/6/09 at 03:27 PM |
important bolts always do that to me. engine mounting bolts and the like. the ones where i've only got exactly the number i need, they go
missing for a month at a time
________________________
LoMoss
posted on 1/6/09 at 03:30 PM |
Think its called tool blindness. Its not just mechanic tools but building and DIY tools. And the symptoms only get worse!
Thats why I have 2 of everything.
Moss
NigeEss
Yep !
And I'm sure the buggers run away when I put them down as seconds later they vanish.
Land Locked
posted on 1/6/09 at 03:31 PM |
Mike
Only locost till you go out to buy a new one before you find the old one Happens to me all the time.
SteveWalker
posted on 1/6/09 at 03:33 PM |
I spend more time looking for tools than doing any work! Usually not only do I know that I've got the tool, but I know that I've seen it
recently, but I just can't find it.
Screwdrivers are the worst. I can sit down in the living room and slacken off a network socket, connect another socket to the spare cable and then
when I come to fasten the faceplate back, the screwdriver has vanished. After much searching, I find it on the other side of the room - at no point
before starting the search have I moved from my sitting position!
Lightning
posted on 1/6/09 at 03:44 PM |
What I want to know is when you need a flat head screw driver your draw is full of cross heads and yet when you want a cross head its full of flat
heads????????
Who is it that changes them, and why do I have lots of 14mm spanners and never find a use them
[Edited on 1/6/09 by Lightning]
Litemoth
posted on 1/6/09 at 03:57 PM |
Black Hole Floor
I can relate but I also have a floor that absorbs things that I drop. I can watch it (often in slow motion) fall but it disappears as soon as it hits
the floor or finds the energy to bounce 30 yards away. It yields things days later when I'm looking for something else i've dropped.
It also moves that bolt, clip or spanner just out of reach when I've got the heavy awkward thing just in the right position.
mistergrumpy
posted on 1/6/09 at 04:15 PM |
Ah, the nack to looking for things that you see drop is to look in the total opposite direction to which you last saw it.
I'm not limited to tools. I seem to lose 1 shoe or 1 sock or 1 girlfriend (thats my excuse for being single anyway and I'm sticking to
it!)
stevec
posted on 1/6/09 at 04:17 PM |
Its probably still in the last cap head screw you tightened, got left behind.
yellow melos
posted on 1/6/09 at 04:40 PM |
Not just tools or screws/bolts.... also pens.. credit cars... e-mails you sent.. e-mails you started to write.. websites your sure you have been
too....the bacon roll you started to eat for breakfast... the list you was writting about all the thinks you have misplaced..
the list goes on and on .... if only i could remember where i put it
nitram38
posted on 1/6/09 at 04:55 PM |
Why is that it is always the 10mm spanner that I lose or goes missing?
SteveWalker
posted on 1/6/09 at 05:13 PM |
it!)
So you still have one shoe and one sock - you should have started with two girlfriends
Stuart_B
posted on 1/6/09 at 05:33 PM |
my tool's run away from me to, such as normaly 13mm spanners and sockets,
so i brought 4, 13mm spanners, and 3, 13mm sockets, i am lucky if i find one. but i do try and hang them all back up on the tool boards.
stuart
posted on 1/6/09 at 06:18 PM |
I gave in to that one some years back and now have half a dozen 10mm spanners strewn around the place for easy location
posted on 1/6/09 at 06:38 PM |
ye gods i thought i was just me
Imagine having that problem but using tools all day at work? It drives me spare.
mistergrumpy
posted on 1/6/09 at 07:09 PM |
If a tool went missing at work in the RAF, you weren't allowed home until it was found in case it was sat in an engine or summat. I remember one
time a socket turning up on top of a giant axle stand and was only found by the hanger giant and another time, one lad used to do an hours RAf work
then an hour building his many pit bikes. Queue another missing socket. It turned up still on the engine of the bike that he'd sold earlie in
the day to someone off camp!
As for putting up with 2 girlfriends, I'd rather stick with the limp because of having one sock and shoe!
kipper
posted on 1/6/09 at 07:55 PM |
tool fairy's
I went to Halfords to buy a repacement 19mm spanner which I lost from a set I bought a long time ago and managed to keep complete until weekend before
last .I last used it to check over the suspention while at melbourn drag meeting.
Could'nt find it anywhere .
I removed the bonnet from the car on Sunday,,,, there was the old one on the scuttle, not hidden , just sat there looking at me. Bloody tool
fairy's
Denis.
Where did that go?
james h
posted on 1/6/09 at 08:03 PM |
Thing is, as soon as you have a tidying session, tool blindless becomes worse - I know where everything is before I put it away!
mr henderson
posted on 1/6/09 at 08:34 PM |
People say it gets worse, it's always been pretty bad for me. On day about 20 years ago I was working on a car, and lost the spanner I needed. I
know I'd had it because I couldn't have taken the bolt off without it. I also knew I hadn't moved from my spot. I got really quite
cross (understatement).
Eventually I found what the spanner had done. It had, quite of its own volition, decided to climb up the wheel and balance itself on top of the tyre.
How it did that, and without me spotting the movement, I still don't know.
I remember it because I remember how cross I got (very)
John
clairetoo
posted on 1/6/09 at 08:48 PM |
I find the easiest way to find a lost tool is to find something else to do - as soon as you stop looking , the missing tool gets bored playing hide
and seek and magically re-appears .
Allso - why is everything you lose , allways found in the last place you look ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
