Author: Subject: pinto fuel system
*davies144*
posted on 1/6/09 at 05:00 PM Reply With Quote
pinto fuel system
hi do i need a fuel vapour system, and if i do what does it do?? cheers ben
RichardK
posted on 1/6/09 at 06:01 PM Reply With Quote
Never heard of one so I haven't!!
Rich
Gallery updated 11/01/2011
posted on 1/6/09 at 06:25 PM Reply With Quote
In a word - NO.
If you're running carb(s) then you shouldn't even need a fuel return line either although if you're building from scratch it's worth putting the pipe run in place in case you want move to an injection set-up later.
*davies144*
posted on 1/6/09 at 08:31 PM Reply With Quote
ok so is it not part of the fuel tank breather? and i dont intend on running fuel injection so could i get rid of it and if so do i take the pipe off at the sender unit? ben
posted on 5/6/09 at 08:09 AM Reply With Quote
fuel tank outlet -> fuel filter in -> fuel filter out -> mechanical fuel pump in -> fuel pump out -> carb in
Ditch anything else.
The tank wll need to be vented in some way. Either a vented filler cap or a second outlet (top of tank) with a one way valve or hose looped over and finishing below the bottom of the tank.
