cd.thomson
posted on 1/6/09 at 08:53 PM |
wtd: solderable copper olives
sorry for posting two wtds in one day, but I could also do with some of those solder-on copper olives for the connection between my rubber fuel hose
and my copper fuel line.
Anybody know of a small volume supplier, or have any going spare? my copper pipe is 8mm ID.
(and steve if you read this.. I have taken your comments on board and will be avoiding using 3 jubilee clips at each join! )
[Edited on 1/6/09 by cd.thomson]
Craig
Macbeast
posted on 1/6/09 at 08:55 PM |
B&Q do 8mm fittings including olives.
blakep82
posted on 1/6/09 at 08:56 PM |
if you're really really stuck let me know, coz i'll need some in the coming weeks, and i know where i can get them in pack of 4, but i
didn't want to go out for them yet
________________________
rotax78
posted on 1/6/09 at 08:57 PM |
how many do you want? u2u me your address
cd.thomson
posted on 1/6/09 at 09:08 PM |
u2u rotax, and I'll U2U blake if I get desperate
Craig
DavidW
posted on 1/6/09 at 09:17 PM |
I got a small amount from eBay.
I may have a couple left if you get stuck.
LBMEFM
posted on 1/6/09 at 09:18 PM |
Plumbers merchants, microbore central heating fittings. Barry
rotax78
posted on 1/6/09 at 09:23 PM |
u2u replied
blakep82
posted on 1/6/09 at 09:30 PM |
thats what all the girls say
lsdweb
posted on 1/6/09 at 10:04 PM |
WHat about a bead maker instead?
http://www.youtube.com/watch?gl=GB&hl=en-GB&v=2MwmDJuOGwU
mangogrooveworkshop
posted on 1/6/09 at 10:49 PM |
thats the way its really done
a4gom
posted on 2/6/09 at 07:10 AM |
on 8mm pipe?
Perfect planning prevents pi$$ poor performance!
cd.thomson
posted on 2/6/09 at 07:16 AM |
I'm sorted now guys, rotax is sending me some.
Although the bead maker is very snazzy, I'm not sure it would fit inside my pipe and because its for fuel pipe I would like a continuous band
around the lip to prevent leakage.
Craig
ashg
if its only 8mm why dont you just use a brake pipe tool to flare the end? the set i have does up to 10mm.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
blakep82
posted on 2/6/09 at 07:48 AM |
i think the copper olive is his best way too
cd.thomson
posted on 2/6/09 at 08:04 AM |
because thats not free
Craig
wilkingj
posted on 2/6/09 at 12:30 PM |
Buy or make a tool like the one in the YouTube video.
B&Q do those Pliers, at £13. (Metal Oyster Kit B&Q part no 0000003344668
None in stock near me
You could weld a blob on a set of molegrips and cut a slot (or drill the right sized hole) in the other jaw to make them.
Simples... chk (and typically Locost)
Best Regards
Geoff
http://www.v8viento.co.uk
