Author: Subject: pinto fuel system again
*davies144*
posted on 3/6/09 at 05:43 PM Reply With Quote
hi, jus to make 100% clear i now know that i dont need the fuel vapour separator, but what do i do with the pipe that was run to it, and goes back to the top of the tank? do i take it off at the tank or put a filter breather on the end of the pipe? cheers again ben
RichardK
posted on 3/6/09 at 05:50 PM Reply With Quote
Just think of it like a big fuel filter, you have fuel in and fuel out, the tube at the top is where the vapour came out, in fact why not get a fuel filter and use that to join the two fuel pipes together?
Having read your post thoroughly now Yes take it off at the tank! But put one of those 1 way fuel breathers on in case you roll your car.
Rich
[Edited on 3/6/09 by RichardK]
Gallery updated 11/01/2011
SteveWalker
posted on 3/6/09 at 08:30 PM Reply With Quote
My carb is set up with two connections at the carb itself.
The clear, fibre reinforced hose feeds into the carbs integral filter housing and then vapour/excess fuel exits the filter via an orifice into the black hose for return to the tank.
