Author: Subject: your thoughts on this please
omega0684
posted on 4/6/09 at 07:39 AM Reply With Quote
just seen this rad on ebay
i e-mailed the guy and he says that the rad is 17" tall (430mm) 14.5" wide (370mm) and 2" deep (5mm), priced at £109 i think thats quite good value and it would sit in my nosecone quite nicely. ideally i would want it about 400mm wide but thats no biggy,
the only thing that i have a question about is the pressure cap, as there would be one on the header tank, is it ok to have 2 on the coolant system?
speedyxjs
posted on 4/6/09 at 07:43 AM Reply With Quote
I dont see why not. It just means they wont have to release as much pressure as normal (sharing the work).
If you wanted, im sure you would be able to find a non pressure relief cap to fit
andyd
posted on 4/6/09 at 07:46 AM Reply With Quote
Yep, get a non-pressure one for the rad and put the pressure one on the header tank. Plenty of production cars have that arrangement.
iank
posted on 4/6/09 at 08:01 AM Reply With Quote
What's the point of spending 4x as much as an alloy VW polo radiator? They've been used to cool very powerful engines so are more than up to the job for 99.9% of people.
Most cooling problems reported seem to be a lack of ducting around the radiator or airlocks not lack of capacity in the radiator.
Edit: Just seen your other thread. Without any ducting to your current rad most of the air will be lost around the gaps - air travels the route of least resistance so you need to persuade it to go through radiators that aren't right at the front.
[Edited on 4/6/09 by iank]
Anonymous
Mr Whippy
posted on 4/6/09 at 09:14 AM Reply With Quote
as iank says, its virtually the same size as a polo rad and although its definitely better looking, it will give almost identical performance. The matrix even looks the same thickness -
[Edited on 4/6/09 by Mr Whippy]
