Author: Subject: Still looking for a gearbox.
stevetzoid
posted on 10/6/09 at 02:50 PM Reply With Quote
Hi all,
I am still looking for a 4 speed gearbox with 23 splines input/output I beleive it's the "rocket Box" can anyone help!!. needs to be 23 splines for the stronger box and not the 5 speed.
Regards Steve Evans.
blakep82
posted on 10/6/09 at 02:55 PM Reply With Quote
be quick!
the rocket box's proper name is the type E
the 5 speed type 9 has the same 23 spline shaft (just coz you said it needs to be 23 splines for the stronger box)
they're the same physical size.
i think the rocket is a little stronger though
how much power are you wanting to put through it?
[Edited on 10/6/09 by blakep82]
________________________
luke
posted on 10/6/09 at 03:51 PM Reply With Quote
Blake, if you look at your link the questions at the bottom someone asks how many splines on the input shaft and he says 20.
blakep82
posted on 10/6/09 at 03:54 PM Reply With Quote
oooooh, right... ignore me!
flak monkey
posted on 10/6/09 at 03:55 PM Reply With Quote
The type 9 is a 23x1" input shaft, identical to the type e box.
Unless for some reason you specifically need the 4 speed i would just stick a type 9 in.
Sera
http://www.motosera.com
blakep82
posted on 10/6/09 at 04:04 PM Reply With Quote
^ yep, 5th would be nicer on motorways anyway
david, wasn't the type e a bit stronger though? or was the 5th gear the only difference?
nib1980
posted on 10/6/09 at 04:36 PM Reply With Quote
i have a type 2 if anyone is interested? I know this man isn't but someone may be?
goodguydrew
posted on 10/6/09 at 07:02 PM Reply With Quote
I have a spare 4 speed. It's like a 4 speed type 9. I'll count the splines tonight.
flak monkey
posted on 10/6/09 at 07:09 PM Reply With Quote
I think the boxes are physically the same. The weakest point in the type 9 is the laycluster needle roller bearings. In a HD box these are replaced with a proper roller bearing. As far as I know the laycluster design is identical between the 2 boxes.
Sera
goodguydrew
posted on 10/6/09 at 10:35 PM Reply With Quote
My 4 spped seems to have 22 input splines and 25 output. Any use?
