RMarine
posted on 13/6/09 at 01:03 AM |
Type 9 Gearbox
Hi, what do i need to do to a std type 9 to fit a 2.0 zetec engine?
M$RK_VXRD
posted on 13/6/09 at 01:14 AM |
check out westfield world they have info on there
linky
dewbries
posted on 13/6/09 at 07:27 AM |
Have a look here:
http://www.zetecinside.com/xr2/gearbox.shtml
Second build. Now refining and changing drive train
big_wasa
posted on 13/6/09 at 08:24 AM |
Nothing
You will need a bit of mix and match on the clutch though.
RMarine
posted on 13/6/09 at 11:27 AM |
what type of mix and match?
big_wasa
posted on 13/6/09 at 12:33 PM |
There are lots of combinations that work
one is
1.8 flywheel
early mondeo clutch kit with 220mm clutch with 23 spline 1" center.
Longer thrust bearing from an early 4spd box ( do a search for part Number )
and dont forget the spigot bearing from any sierra.
The tin cover from the T9 needs a bit welding onto it to cover completley.
RMarine
posted on 13/6/09 at 12:47 PM |
any links for instuctions and pic's ?
