asl
posted on 13/6/09 at 07:02 PM |
Castle Coombe
Hi all. I'm doing a day at CC in a few weeks. Has anyone here done a session there and able to give me some pointers? Cheers
s2gse
posted on 13/6/09 at 07:57 PM |
will let you know what i think as im doing a track day there on the 19th
life's to short and so was the drive
jeffw
posted on 14/6/09 at 07:29 AM |
Castle Coombe is the one circuit in the UK my insurance wouldn't cover.....
The problem with Coombe is there is very little run-off in Quarry, Tower & Camp corners. All pretty low speed corners after high speed straights.
There is a pretty major bump in the slight left hander that leads into Quarry, make sure you are braking before that and don't brake over the
bump and finish braking before you turn.
Treat Coombe with respect by starting slowly and learn the circuit. Be smooth and leave yourself enough braking area and you'll be fine, push
too hard too early and you'll be in the grass bank.
Have a look on youtube for the onboard track laps people have done and enjoy yourself.
asl
posted on 14/6/09 at 03:03 PM |
jeffw, good feedback thanks.
S2gse, I'm there the following friday so any info you have will be greatly appreciated.
wheezy
posted on 17/6/09 at 01:40 PM |
As jeffw stated there is very little run off area at Castle Combe. Most of the big off's seem to be at quarry which is at the end off the main
straight. Make sure you use the braking and turn in markers till you get up to speed. As you rise up to quarry stay over to the right, brake to kill
some speed the turn slightly left over the rise. Once you are over the rise brake again for Quarry itself. A good tip is to point the car at a set of
lights above the tyre barrier as you come over the rise so you wont be turning as you go over the top. Also unlike most circuits overtaking at Combe
is done on the right due to the pit entrance being on the left.
There is normally an instructor available on the day at no extra charge so it may be worth asking him to jump in with you.
Dave
asl
posted on 24/6/09 at 06:18 AM |
Thanks Dave, very useful tips!
asl
posted on 24/6/09 at 06:20 AM |
Dave are you going to Combe friday? Just noticed that it was you that put me on to Richard. I will be doing the Silverstone day in sept as well.
Cheers Nathan
[Edited on 24/6/09 by asl]
wheezy
posted on 24/6/09 at 08:02 AM |
Hi Nathan, Yep I will be there. Hope you have packed your waterproofs, the forecast at the moment does not look to promising with heavy thundery
showers in the afternoon![](/images//smilies/sad.gif)
The 2 tracks days I did at Combe last year were both wet as well
See you there.
Dave
lsdweb
posted on 25/6/09 at 09:13 AM |
I'm competing there on Saturday and I don't know anything about the circuit! I did my ARDS there years ago but that was before the two
chicanes had been installed so that's not much help. I've also got the Autopsort guide but that's pre chicane as well.
I probably need to start off slow and build up but that's not that easy with sprints! I'm in a tough class as well with a load of Elises
etc.. There's no standard production car class so I'm in with the modified road going :-(
Looks like I'll need to push the Saxo even harder than last weekend!
Wyn
![](/galpreviews/a971719-JMS_DMJEH_07.jpg) ![Rescued attachment JMS_DMJEH_07.jpg](/gallery/a971719-JMS_DMJEH_07.jpg) Rescued attachment JMS_DMJEH_07.jpg
