Author: Subject: Pocket Dyno
nicksuper6
posted on 14/6/09 at 03:29 PM Reply With Quote
Pocket Dyno
Any one got this on their iphone.Had it on for over a year now and not tried it out.It is meant to measure 0-60 bhp and loads more.You have to load a bit of info in phone first like cars weight etc,to get best results.And the iphone must b steady and fixed down.That might be a bit tricky.Any way will try it out soon and share results. http://www.pocketdyno.com/
nick
Daimo_45
posted on 14/6/09 at 03:39 PM Reply With Quote
Results
Not too bad for a $12.99 application.
posted on 14/6/09 at 03:56 PM Reply With Quote
Presumably that's just someone who's copied Dynolicious?
posted on 14/6/09 at 03:57 PM Reply With Quote
Originally posted by Daimo_45
Results
Yes but that's their own testing!!! What you will actually get in real life may well be different....
nicksuper6
posted on 14/6/09 at 04:19 PM Reply With Quote
Done some searching and have seen test results compared to rolling road,closser than you think
iank
posted on 14/6/09 at 05:38 PM Reply With Quote
With inbuilt GPS and a reasonably accurate timer it's not rocket science to produce something that can do that.
Anonymous
gingerprince
posted on 14/6/09 at 05:45 PM Reply With Quote
The actual figures may not be 100% accurate (then again, are rolling roads, there's that much variation!) but it's very useful for like-for-like comparisons when making modifications. e.g. put a chav exhaust on and see how much power you lose.
Antnicuk
posted on 14/6/09 at 05:53 PM Reply With Quote
i bought dynolicious for my i phone ages ago but havent used it. I have much better things to think about than trying to set it up when i'm on the track... its supposed to be very accurate
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
nicksuper6
posted on 14/6/09 at 06:03 PM Reply With Quote
Will post results when i get a few runs in.Must remember to take to Newlands Corner on next run to get results from other cars
afj
posted on 14/6/09 at 06:16 PM Reply With Quote
just downloaded the free version on the app store on my touch got 5.5 sec 0-60 and 13.9 1/4mile BUT says ive got 36 bhp
eerrrrrrrrrrrrrrrr
iank
posted on 14/6/09 at 06:40 PM Reply With Quote
Does it want the car weight in kg or lbs? That could be a factor of 2.2 to start off with
Anonymous
nicksuper6
posted on 15/6/09 at 06:41 PM Reply With Quote
weight is in kgs u must also add your own weight.Dont b shy and tell the truth
