Author: Subject: Transit van as donor?
Alex.
posted on 16/6/09 at 08:29 PM Reply With Quote
Hi Guys,
I've been offered a transit van as a donor, really cheap, is it feasible?
It is a 1990 G reg mk3 with a 2 litre pinto petrol engine and a live axle rear end. Looks like it should work....
Alex.
blakep82
posted on 16/6/09 at 08:36 PM Reply With Quote
no reason why not! what gearbox has it got? and the ratio of the diff?
it might be geared differently to a sierra or capri for example, but its definitely possible
________________________
jpindy3
posted on 16/6/09 at 08:37 PM Reply With Quote
mate you should have a good pinto there,you will need to change the cam and flywheel,
also good if you want to turbo it as it will be low cr
matt_claydon
posted on 16/6/09 at 08:44 PM Reply With Quote
So not really a very good Pinto then
Mark Allanson
posted on 16/6/09 at 08:47 PM Reply With Quote
How much does a transit rear axle weigh?
Alex.
posted on 16/6/09 at 09:06 PM Reply With Quote
Apparently it has a good gearbox that any ford engine can fit to and take lots of power.
Don't know the ratio of the diff, but the transit tops out at about 80 and that's enough for the road. Should give good acceleration...
I can understand the cam and compression, but why the flywheel?
Not sure on the weight, but it does look spindly under the van. It's also square section, so should be easier to weld...
It is if it's free!
Looks like it's a good option, the engine I was going to use may be staying in my daily driver car...
Alex.
paulf
posted on 16/6/09 at 09:20 PM Reply With Quote
But if its got twin rear wheels would be good for traction.
Paul
Steve G
posted on 16/6/09 at 10:29 PM Reply With Quote
It'll help the weight distribution - balance out the big iron lump at the front. Never mind 50:50 weight distribution..... more 100:100
James
posted on 16/6/09 at 11:51 PM Reply With Quote
Isn't it going to have a 5 stud wheel pattern at the rear?
What will you fit at the front that will match?
I don't know, but I'd be surprised if the rear axle wasn't a load wider than an Escort or Cortina.
People give Pintos away now, it's hardly worth the hassle I'd have though.
James
speedyxjs
posted on 17/6/09 at 06:13 AM Reply With Quote
Paul
A 6 wheeled locost!!!
Am i right in thinking that a transit pinto is taller than a sierra pinto? (not sure where i recall that from)
gavin174
posted on 17/6/09 at 08:10 AM Reply With Quote
get the transit for free...
then sell it for spares or repairs probably get £200 and put this towards sierra donor!!!
jollygreengiant
posted on 17/6/09 at 09:54 AM Reply With Quote
Paul
The sum is a lot deeper.
iank
posted on 17/6/09 at 10:49 AM Reply With Quote
I was also thinking the axle would be very wide.
Anonymous
Alex.
posted on 17/6/09 at 07:08 PM Reply With Quote
Well, I can measure the width of the transit axle, but how wide is an escort axle for comparison?
Alex.
flak monkey
posted on 17/6/09 at 07:12 PM Reply With Quote
Alex.
54" if memory serves me right?
Its just not worth it. The gearbox is strong but the ratios are odd. The engine is a low compression one (no good for reliable turboing as its only cast pistons) and very low on power.
Save your time and just get a sierra
Sera
http://www.motosera.com
speedyxjs
posted on 20/6/09 at 07:24 PM Reply With Quote
Alex.
Cant be much wider than my jag one. The transit and the jag have virtually the same rear track width.
Ninehigh
posted on 24/6/09 at 05:59 PM Reply With Quote
I say do it, you can always change the rear axles and hubs can't you?
I suppose it depends how much the transit is
