benlg924
posted on 17/6/09 at 07:42 PM |
Bike Carb Throttle Return
Hi All
i have finally finished my carb conversion on the 924 and after having a while with the throttle staying open i realised i would need a spring to
bring it back around.
i have one but it has made pedel pressing quite stiff due to the way the spring is resting and curving around the throttle spindle (thing)
is there a better way to install a return spring?
if people could post pics of how they have got round this issue that would be great i am getting a very big right leg and its causing me to walk in
circles now!
Ben
posted on 17/6/09 at 07:49 PM |
I had the same problem but since getting the carbs set up at Bogg Brothers I don't need it any more.
More a mixture setting problem than anything else IMO...
posted on 17/6/09 at 07:50 PM |
Don't bike carbs have 2 throttle cables , one to open and another to close the throttle? Can you use what would have been the closing cable
fitting to fit a cable compressing a spring? If that makes sense?
benlg924
posted on 17/6/09 at 07:55 PM |
it does have a return cable not attached
i have the accelerator attached the the front fixing
and the sping to the rear fixing but the spring rubs on the big spindle
i could attach a cable to the return section of the spindle but where would i then attach that?
benlg924
posted on 17/6/09 at 07:57 PM |
i have also had them set up by walford motorsport fully fitted and dyno'd ect
just this return issue now
how did bogg brothers sort yours?
Flamez
posted on 17/6/09 at 08:22 PM |
Mine are set the other way round. On the return use a short piece of cable and thread up through the adjuster, place a spring around the cable, and a
clamp on top of the cable to hold it in place. Do not put too much tension on the spring as it will also act asa throttle stop.
If you do a search others have posted pictures,
http://www.locostbuilders.co.uk/viewthread.php?tid=113977
scroll down for slaters reply and pictures. HTH
my build mac1motorsports
Slater
posted on 17/6/09 at 08:39 PM |
Thanks Flamez for posting that link.
That solution works a treat.
Ben, if you need a spring or two let me know, I have a big selection box and can post some to you. You will need to supply a couple of small coins
though!
Keith
[Edited on 17/6/09 by Slater]
benlg924
posted on 18/6/09 at 07:54 AM |
hi
great idea looks like the way to go, are they just 5p's?
cheers for that slater i have struggled to get any spring from round here would it be possible to get two springs? also dont suppose you have any
solderless nipples i only have 1 left? if you let me know i can paypal expenses in for you.
I will pm my address now
Ben
Slater
posted on 18/6/09 at 09:11 AM |
Ben
Yes thay are 5p's with a small hole drilled through. I can send you a few springs, on Saturday. You can get a solderless nipple from a choclate
block connector, just trim off the plastic.
If you look at the photo you could get away without using the brass tube, as long as the bottom 5p is resting on something solid.
Keith
DarrenW
posted on 18/6/09 at 09:37 AM |
A simple solution is to fit the twin cable set up off the bike, then fit a cleat to the throttle pedal that your foot can clip into (like on
pushbikes). Job done and no need for springs at all.
Only joking BTW. I had same problem, bought a set of springs and played about with different ones and mounting points until best compromise was
obtained.
[Edited on 18/6/09 by DarrenW]
benlg924
posted on 20/6/09 at 12:12 PM |
Hi guys
all sorted now thanks to everyone on here and slater for the parts (legend)
Before
after
ps used 2p's due to credit crunch!
Ben
