Author: Subject: sierra diesel
subk2002
posted on 9/3/04 at 07:17 PM Reply With Quote
sierra diesel
Hi guys can i use a diesel sierra for my donner parts ie hubs,drive shafts, ,prop,steering rack & colum,??
im putting a bike engine in
Cheers Drew
Mk-Ninja
posted on 9/3/04 at 07:24 PM Reply With Quote
Yes, but just check the diff ratio to see if it will do for a BEC.
HTH Gordon
I'm sure I've got one, just don't know where I've put it
subk2002
posted on 9/3/04 at 07:46 PM Reply With Quote
Im going for a 4x4 diff if i can get one cheep thanks
Mark Allanson
posted on 9/3/04 at 08:04 PM Reply With Quote
Not really into bikes, but I thought you needed the highest ratio you could get for a bike engine, the 1.8TD has a 3.92:1 diff if its any help
greggors84
posted on 10/3/04 at 12:46 AM Reply With Quote
I thought u needed a lower one, but am probably completely wrong1
Chris
The Magnificent 7!
elitewiring
posted on 10/3/04 at 01:26 AM Reply With Quote
for a bike engine car you need a lower ratio ie 3.38 or 3.54.
a 3.92 wouldn't be any good, i would give a car that revs too high, which wouldn't give a very good cruising speed.
subk2002
posted on 10/3/04 at 05:28 PM Reply With Quote
So whats the best diff to get for a bike engine kit???
elitewiring
posted on 11/3/04 at 10:12 PM Reply With Quote
i personally think the 3.38 gives the best of both worlds, a car that can cruise and scream when you want it to. the only problem is they are very hard to get hold of, i think they were fitted to the estate sierra (maybe auto only) there is a list in the front of the haynes manual.
a 3.54 is another good one and alittle easier to find. dont fit a 3.62, you'll end up with a car that will only do about 105/110, 0-60 will be good if your tyres are up to it.
note, you can't (afaik) get 3.38 lsd unless you pay quiafe money.
