Author: Subject: Best place for Fuse Box?
Blairm
posted on 9/3/04 at 07:19 PM Reply With Quote
About to start making my own loom. Any suggestion as to the best location for the fuse box to keep it as tidy as I can. As I am not modifying the escort loom I figure I have a little more flexibility
Cheer Blair
stephen_gusterson
posted on 9/3/04 at 07:46 PM Reply With Quote
near to battery. you dont want unfused wires from battery to box to be long lengths
unless you want an electrical fire....
atb
steve
Blairm
posted on 9/3/04 at 08:09 PM Reply With Quote
Thanks, But what if the battery is rear mounted?
Cheers Blair
Staple balls
posted on 9/3/04 at 08:11 PM Reply With Quote
Cheers Blair
um, put the fuse box at the back? y'know, if you get a nice little fire near your fuel lines. that's gonna be great fun that.
Fifer
posted on 9/3/04 at 08:30 PM Reply With Quote
Lots of cars have battery at rear (Jag XJ6 for one), if you use very heavy duty cables for main run to starter solenoid, keep them well insulated and clear of metal !, and fit an inline fuse link for the feed to the fuse box etc, you will be fine and dandy.
posted on 9/3/04 at 08:35 PM Reply With Quote
ideally a pair of jump leads to the front, since the wires will be up to ten times as long thats a lot more voltage drop down the length.
posted on 9/3/04 at 09:55 PM Reply With Quote
Apart from "near the battery", somewhere that isn't likely to get water running over it is a good idea. Either that, or a REALLY waterproof cover!
rgds,
Blairm
posted on 9/3/04 at 10:02 PM Reply With Quote
Hi Thanks for all the advice. I have 32mm cross section (100mm diameter approx) cable running to the starter relay at present. Should I run a seperate heavy earth or will the chassis be OK?
stephen_gusterson
posted on 9/3/04 at 10:08 PM Reply With Quote
The chassis will be more than OK.
I dont think you mean 100mm or 32mm do you?
yep - many cars DO have the battery at the back - ther current beemer 3 series does.
If you do put the battery in the rear you need a thick cable thats WELL PROTECTED cos if it shorts, it wont be fused at all. Id suggest taking it to a common point at the front - like starter solenoid - then bringing a cable up to a power distribution stud - insulated - and use that to spur off short leads to the fuses in the fuse box.
Run the thick cable the rear in round plastic conduit if I were you.
why cant the battery fit the front - mines in the bulkhead centre inside the bonnet.
Julian B
posted on 9/3/04 at 10:32 PM Reply With Quote
A battery in the rear is exactly what i was thining of doing. I would like to fit a heater alla caterham. This takes up quite a bit of bulkhead room so a boot mounted battery would be nice nice.
stephen_gusterson
posted on 9/3/04 at 10:47 PM Reply With Quote
i managed to squeeze a mini heater inside the scuttle, but it is tight
atb
steve
Blairm
posted on 9/3/04 at 10:56 PM Reply With Quote
Sorry Guys, I meant 32 Square mm cross sectional area for the battery cable.
The reason it is in the back is that is the way the McGregor Chassis I am using in New Zealand is set up.
I head the warning about shorts and am running it on the opposite side to the fuel line and will look at conduit for saftey.
Cheers Blair
Blairm
posted on 9/3/04 at 10:59 PM Reply With Quote
Stephen,
you mention an insulated stud for distribution. What do these look like?
Cheers Blair
timf
posted on 10/3/04 at 08:55 AM Reply With Quote
posted on 10/3/04 at 09:14 AM Reply With Quote
FWIW, my battery ended up in the passanger footwell and ground level.
James
posted on 10/3/04 at 09:30 AM Reply With Quote
Yeah that's my plan too- keep all that weight nice and low!
James
posted on 10/3/04 at 09:45 AM Reply With Quote
plus its the passanger who loses space! all good...
stephen_gusterson
posted on 10/3/04 at 01:59 PM Reply With Quote
actually, I made my own.
I got a peice of plastic about 50mm square, 10mm thick, and put a 10mm bolt / stud thro the middle.
I drilled some fixing holes in the corners of the square, and mounted it from the dash side of the scuttle with the stud passing thro a big clearance hole into the bonnet side. The battery, alternator and starter cables junctioned to the side poking into the bonnet side of the scuttle, and the live feeds to the fuses and whatever come from the side within the dash area.
Tims suggestion looks same kinda idea, but mine looks more 'ballsy'.
atb
steve
[Edited on 10/3/04 by stephen_gusterson]
alfasudsprint
posted on 10/3/04 at 07:20 PM Reply With Quote
Steve,
so where is the fuse box, under the scuttle??? does your website show any of this...(am looking now!)
Tim
stephen_gusterson
posted on 10/3/04 at 10:38 PM Reply With Quote
I have two 8 way fuse boxes. In the pic you can just see the upper one to the right of the battery.
The 'thro stud' is being hidden by the battery - its fairly close to its side.
The fuse boxes are mounted from the rear of the scuttle, into oblong holes, so that the fuses can be accessed from the bonnet. Its a bit crowded there, with the ABS valve block and washer tank, but its acessable.
atb
elitewiring
posted on 11/3/04 at 01:58 AM Reply With Quote
it looks like on a couple of fuses are fitted, (this could be my eye sight), say 6 out of the possible 16, is this right, if so why ?? or are you in mid build???
i dont mean to question your car just interested.
stephen_gusterson
posted on 11/3/04 at 09:06 PM Reply With Quote
cos when the pikky was taken - and is still the case - most of the bodywork and subsequent fitted lights etc are not fitted!
Most wires are open ended at the destinations.
I just have the fuses for iginition and horn fitted (and heater motor in the one below). Not fitting fuses until needed is a good way of isolating incomplete circuits!
atb
steve
[Edited on 11/3/04 by stephen_gusterson]
jmbillings
posted on 18/4/04 at 10:49 AM Reply With Quote
Our Battery is in the engine bay on the passenger side with the main ignition/permanant feeds to the ignition switch going throught the bulkhead. The fusebox is under the scuttle on the passenger side, and any cables that need to pass back through the the engine bay (lights/instrument senders etc) go through 2 big multiway plugs that Steve found.
