Author: Subject: Making Windscreen
myke pocock
posted on 24/6/09 at 07:14 PM Reply With Quote
Making Windscreen
Has anyone on here constructed a windscreen using the instructions in The Book? Does it work exactly as said or are there problems to keep in mind? Where have you sourced the channel and rubber? Is the Lolocost channel and rubber any good?
dewbries
posted on 24/6/09 at 07:35 PM Reply With Quote
got mine through robinhood but did not use the rubber got some black silicone or PU can't remember. Bending the channel is easy if your care full. Make a ply template and bend the channel round using your hands and perhaps a couple of quick clamps to hold the top edge straight.
Second build. Now refining and changing drive train
speedyxjs
posted on 24/6/09 at 07:43 PM Reply With Quote
Just a suggestion, most people go through SVA/IVA without a windscreen or aeroscreen as it means there is less to test (less to fail on)
myke pocock
posted on 24/6/09 at 07:59 PM Reply With Quote
Dont worry, this is a post SVA question!!!!
whitestu
posted on 24/6/09 at 09:11 PM Reply With Quote
If you haven't thought about where you will get the glass try to local glass cutters. I just got a piece of laminate to replace my cracked Caterham screen. It was £35, which was a pleasant surprise after being quoted £220 at Autoglass.
Stu
mark chandler
posted on 24/6/09 at 09:39 PM Reply With Quote
Defeated me rolling the surround, ali kept rippling so got a Westfield SE frame off Ebay for £15, glass cost another £50 to havecut from a bit of laminate.
Fits my book width bulkhead but it does taper in slightly.
Regards Mark
