Author: Subject: Temp sender
vinnievector
posted on 24/6/09 at 09:02 PM Reply With Quote
Temp sender
Hi all,
At some stage in my Pintos life the Temp sender hole was drilled and tapped out to 8mm as i found out when i tryed to fit a standard Ford one , so at the moment i have 8mm bolt with ptfe just to plug the hole so i can run the engine ,any one know a 8mm metric sender i could fit before i go to the motor factors and trawl through there senders. cheers vin
DarrenW
posted on 25/6/09 at 11:14 AM Reply With Quote
Have you tried looking on ETB website. They sell various senders but i dont know if they will have the size you need. They may however have an adaptor that you can buy that you can drill, tap and fit first.
