Author: Subject: USB to Cat5 cable adapters .... they work!!
Jasper
posted on 25/6/09 at 03:26 PM Reply With Quote
A while ago I posted that I needed an extra long USB cable to find out it's rather more complicated with USB cables.
SO .... I bought a pair of USB to Cat5 converts from Ebay. The printer USB cable plugs in one end, then 25 feets of standard network cable, then another converter back to USB and into the PC.
And, guess what, they work perfectly! I was a little suprised I have to say, and they were quite cheap of Ebay.
It's nice when a plan comes together.
Charlie_Zetec
posted on 25/6/09 at 03:41 PM Reply With Quote
I used some of them recently, as I've helped a friend kit out his garage with some kit. We now have a wall-mounted, flexi-armed monitor and keyboard/mouse in the garage, with the base unit securely inside the house.
I must say, it does help with autodata at your fingertips.
But yes, smart little bits of kit, and I'd definately recommend them!
Guinness
posted on 25/6/09 at 03:49 PM Reply With Quote
Nice one!
I've suddenly found a use for the 400 m of CAT5E cable I've got in the garage!
Mike
house19uk
posted on 25/6/09 at 03:54 PM Reply With Quote
Understand the keyboard and mouse but what did youuse to extend the monitor?
posted on 25/6/09 at 04:16 PM Reply With Quote
Originally posted by Guinness
Nice one!
Mike
How far is the garage away from the house then...?
Guinness
posted on 25/6/09 at 04:18 PM Reply With Quote
Nice one!
Mike
Just beyond the moat
posted on 25/6/09 at 04:26 PM Reply With Quote
Nice one!
Mike
....which I sincerely hope we're not paying for the cleaning of
Guinness
posted on 25/6/09 at 04:37 PM Reply With Quote
Nice one!
Mike
Of course not, old chap! But I did sneak a rather nice Duck House through
mookaloid
posted on 25/6/09 at 04:40 PM Reply With Quote
not sure that the standards for Ethernet cable will allow for runs that long - 100m max if I recall
martyn_16v
posted on 25/6/09 at 08:09 PM Reply With Quote
Whether extending USB cables like this works or not is much more down to the devices themselves than the actual cables. It all depends on the mode and amount of bandwidth actually used, and how fussy the USB interface is. I've found that Nikon cameras will quite happily run over a cable length of 40m or so, but some dye-sub printers won't even tolerate a proper 5m USB cable...
