Author: Subject: Rollbar painting Hammerite Spray or brush
chrisspartan
posted on 25/6/09 at 03:51 PM Reply With Quote
Hi all, just contenplating painting my rollbar.
I am planning to use Hammerite Red oxide undercoat and Hammerite satin black as a top coat, question is whether to brush on or spray using their aerosols.
I know they say you dont need undercoat - but it seems to me better with one?
Hammerite tends to be a bit gloopy in my experience so if I went down the brush route I was going to thin it a little bit with their thinners.
Anyone had any experience of using either - can you get a good finish?
Chris
[Edited on 25/6/09 by chrisspartan]
ashg
posted on 25/6/09 at 04:05 PM Reply With Quote
spray it. brusing it on will look crap
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mistergrumpy
posted on 25/6/09 at 04:08 PM Reply With Quote
Hammerite is pump in my experience. What you want and what was recommended to me is a product called Rust O leum. They have a hardened range or words around that effect and it really is good stuff. You still have to use a primer, any will do. I bought a large aerosol of it from the local engineers supplies for about £10 but it does the job and I wished I'd used it on the actual chassis now.
I'd spray whatever you use but in my experience Hammerite isn't that chip-proof so I'd personally use something else....
Def use a good primer.
speedyxjs
posted on 25/6/09 at 04:20 PM Reply With Quote
I sprayed mine
posted on 25/6/09 at 04:23 PM Reply With Quote
I used Halfords red oxide spray primer (after thoroughly cleaning the roll bar with the angle grinder wire brush and washing/drying) built up in 3-4 thin coats. The top coat was done with Plastikote satin black enamel spray (Halfords/Homebase/B&Q) again built up in 5-6 thin coats.
The Plastikote stuff is very durable in my experience (far better than normal spray paint or Hammerite) and gives an almost powder coated looking finish if applied well.
[Edited on 25/6/09 by nick205]
gingerprince
posted on 25/6/09 at 04:24 PM Reply With Quote
I recently did my rollbar in this stuff by Hycote: -
http://www.wilcodirect.co.uk/index.php?main_page=product_info&cPath=167_170&products_id=1939
http://www.wilcodirect.co.uk/index.php?main_page=product_info&cPath=167_171&products_id=1938
Can't comment on durability as I've only done about 150 miles since, but it looks top notch (apart from the bit where I missed a bit sanding the metal - grrr!)
Much cheaper than Hammerite (I paid about 2.50 per can from local motor factors).
posted on 25/6/09 at 04:26 PM Reply With Quote
Sure is! that's what I use. As said matches the powdercoat nicely.
Guinness
posted on 25/6/09 at 04:32 PM Reply With Quote
IMHO the roll bar is the most visable bit of your chassis / metalwork when the car is finished.
Get it finished properly and the car will look great, a poor finish can spoil an otherwise perfect car.
Saw a MEV Rocket last night which had been powder coated in silver / grey metallic. It looked lovely!
Mike
fesycresy
posted on 25/6/09 at 04:48 PM Reply With Quote
I've painted hammerite over red oxide and it wasn't very durable.
Hammerite has it's place, I seem to get better results spraying directly onto porous non-perpared surfaces.
Daddylonglegs
posted on 25/6/09 at 06:48 PM Reply With Quote
I'm with the Plastikote boys, damn good stuff and gives a good finish. I've got a can of blue I've had for a while and I'm using it for my engine block.
JB
Steve Hignett
posted on 25/6/09 at 06:56 PM Reply With Quote
Whichever one you choose (I'm not a fan of hammerite myself) please for the love of everything that is painted SPRAY IT ON!!!!!!!!!!!
maskedavenger
posted on 25/6/09 at 07:55 PM Reply With Quote
get a litre of celulose satin black from ebay and spray it it will be a much better job than a spray can
ReMan
posted on 25/6/09 at 07:58 PM Reply With Quote
hamerite is OK for gates. and wheelbarrows:-0
Spray it satin or gloss black
COREdevelopments
posted on 25/6/09 at 08:14 PM Reply With Quote
Stay away from hammerite, its well over priced! I used UPOL acid etch(expensive but had it for cheap) then used SPEREX FRAME PAINT TOUGH BLACK (IIRC) in a satin finish. lasted over 2000 miles so far. also easier to blend in for touch ups. They advise to bake for a period of time but i used a hot air gun.
atb
Rob
chrisspartan
posted on 25/6/09 at 10:34 PM Reply With Quote
Thanks for all that info - some good locost alternatives there.
Chris
