:{THC}:YosamiteSam
posted on 29/6/09 at 09:26 PM |
busa starter clutch tool
is there a need to use a starter clutch holding tool if removing the clutch on a busa? or any other special tools needed?
Tonto1
posted on 30/6/09 at 03:06 PM |
You don't need the special clutch tool if you're engine is still in the car, just pop it in gear and stick the hand brake on.
In a Westy you can relatively easily access the clutch with the engine still in the car!!
:{THC}:YosamiteSam
posted on 30/6/09 at 08:46 PM |
yea thats what i thought but needed the verdict of the panel - theres always a good tip comes from the forum...
matt_gsxr
posted on 30/6/09 at 08:54 PM |
Assuming a GSXR1100 is similar to a GSXR1300....
I tried the above trick and couldn't get enough welly on it to undo the nut. There are two nuts; one is big (i.e. 50 odd mm, and that
isn't so tight, 90 lb ft) and that is manageable, the other one is smaller and is really tight.
I ended up buying a air gun thing, this is great for undoing the nut. It is more difficult to torque it up correctly, but if you take a photo of how
tight it should be then.....
I used this technique and it seemed to work and it was suggested on the oldskool suzuki forum, but please take the normal "forum
consideration" when deciding what to do!
Matt
[edited for grammar, you never know if your mum might be on the forum! although I think it unlikely now I am 40 ;-) ]
[Edited on 30/6/09 by matt_gsxr]
:{THC}:YosamiteSam
posted on 30/6/09 at 09:11 PM |
Matt
i dont think ill need to take off the clutch basket - just the plates all being well - i dont think they are goosed but best to check before a hefty
bill ensues.
will check the clutch spring length - (23.7mm)
also the clutch bearing too whilst its out - make a decision on what to order up if needed
matt_gsxr
posted on 30/6/09 at 09:24 PM |
sorry I need to learn to read more carefully.
for just the plates it isn't so bad (that is the big nut). Popping in gear with the handbrake is the right solution.
I assume you have that monster circlip too. More tricky than you might expect.
Matt
