Author: Subject: hose woes
Soundwave_666
posted on 5/7/09 at 05:30 PM Reply With Quote
hose woes
I'm installing an 2003 R1 engine in to my Mnr Vortex, and stupidly didn't tag the inlets / outlets for the fuel and colling system.
I've the majority of them through the service manuals, but want to be 100% before I couple them up.
Has anyone please got a picture of an engine with the different connections labelled?
Pdlewis
posted on 5/7/09 at 06:54 PM Reply With Quote
Where abouts in the country are you?
this is rudely stolen from someone on here but shows the bits you are after
r1 cooling
r1 cooling
Build Photo Album
Updated 05/02/2009
Soundwave_666
posted on 5/7/09 at 07:15 PM Reply With Quote
I'm in newcastle upon tyne. I think I've nailed the cooling, and this has definitely confirmed my setup, thanks.
any help with the fuel lines????
thanks
Pdlewis
posted on 5/7/09 at 08:08 PM Reply With Quote
Fuel is easy the input is a fairly long straight pipe under the injectors between injector 1 and 2 the return is a bent pipe on the far right which somes out of a gold coloured round thing on the end which is the pressure regulator sorry for the fluffy description and I cant seem to find a photo which shows them clearly
Build Photo Album
Updated 05/02/2009
Soundwave_666
posted on 5/7/09 at 09:08 PM Reply With Quote
fantastic, that's 2 more ticked off the list.
cheers
Soundwave_666
posted on 5/7/09 at 10:28 PM Reply With Quote
ok, I think I have found out what is causing me the problems with the hoses, and they are the 2 hoses coming from the thermo wax (I think that's what you call it). any more pearls of wisdom?
thanks
