Author: Subject: koso rx2n
JAMSTER
posted on 5/7/09 at 07:32 PM Reply With Quote
koso rx2n
i have an rx2n the problem is the rev counter starts off fine for around 10 mins and then it has a mind of its own 1k 9k 3k at idle the speedo works fine up to about 45 mph and then down to 0 up/down/up/down i have th tacho wired up to pin 11 on the edis module and the speedo of the groved front disk hope someone can help
2.0 zetec gsx tbs fz2001 kent cams ms 2.5 with edis
ashg
posted on 6/7/09 at 12:14 AM Reply With Quote
try using the pickup loop instead fo the direct connection.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
JAMSTER
posted on 6/7/09 at 06:58 AM Reply With Quote
i have done it does the same thing thanks
triumphdave
posted on 6/7/09 at 06:31 PM Reply With Quote
I am still having the same problem with my rev counter.
I fixed the speedo by repositioning it.Originally I was using a toothed wheel on the prop,but know picking up off of the front brake disc bolt heads,this works a treat.
JAMSTER
posted on 16/7/09 at 07:23 PM Reply With Quote
thanks triumphdave got speedo sorted now just the rev counter to get done not far from smashing it. lol
JAMSTER
posted on 23/8/09 at 05:35 PM Reply With Quote
rx2n now sorted
got my rev counter problems sorted sent my rx2n back for inspection. And they found somthing wrong. sent out a new one and it works fine wirerd to pin 11 on my edis
woop woop
