Author: Subject: Has someone already taken out my spigot (picture included)
Jasongray5
posted on 9/7/09 at 10:02 AM Reply With Quote
As above?
Cant see anything with any needle rollers in there. Only a solid little thingy at the very rear of the crank?
What do we think?
crank
crank
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
Land Locked
posted on 9/7/09 at 10:10 AM Reply With Quote
No spigot bearing in there.
RoadkillUK
posted on 9/7/09 at 10:19 AM Reply With Quote
Has the engine been used in a RWD car before?
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Jasongray5
posted on 9/7/09 at 10:26 AM Reply With Quote
Nope! it hasnt, came from a mondeo!
Ideal, means one less job to worry about.
However, i have given myself another, to get a better look, I popped off the crank seal thing. Can i get the bastard back in there....
Can someone confirm that i need to lower the sump a little to get the Fu*ker back in to its rightful place?
How hard can it be?
fatbaldbloke
posted on 9/7/09 at 10:45 AM Reply With Quote
There's some notes and photos on installing the crank seals on my website. The link is below, then go to the Westfield bottom end rebuild page.
adithorp
posted on 9/7/09 at 10:46 AM Reply With Quote
Should fit without dropping the sump but don't re-use the seal. Fit a new one.
http://jpsc.org.uk/forum/
philtvr
go to ford and buy a spigot (about £11) and it pushes in to hole in the end of the crank. Front wheel drive cars don't use them hence you have to fit one to use it in a 7. As for the seal no idea but i would buy a new one not just shove the old one back in.
Jasongray5
posted on 9/7/09 at 10:56 AM Reply With Quote
anyone got anywhere go go buying one please?
Cheers for the advice thus far!!
How hard can it be?
Jasongray5
posted on 9/7/09 at 10:57 AM Reply With Quote
Oh, and which way does the spigot go, needles front or back??
How hard can it be?
UncleFista
posted on 9/7/09 at 11:02 AM Reply With Quote
One end of the bearing is very slightly more rounded, that end goes in first facing the engine
Just tap it in with a small hammer using a suitably sized socket as a drift, it's pretty obvious when it's all the way in.
Tony Bond / UncleFista
Jasongray5
posted on 9/7/09 at 11:15 AM Reply With Quote
does it go until it goes no more?
How hard can it be?
UncleFista
posted on 9/7/09 at 11:16 AM Reply With Quote
Yes, and the clanging of the hammer changes tone to a more solid sound
Jasongray5
posted on 9/7/09 at 11:20 AM Reply With Quote
Cheers Tony! Going to give it a bash in a moment!
Any advance on where to get the oil seal from anyone?
How hard can it be?
posted on 9/7/09 at 11:26 AM Reply With Quote
Hmm, of no use to you what so ever but when I dragged my zetec out of a rather banana shaped Focus and took the box off I was surprised/pleased to see a spigot bearing already in there
posted on 9/7/09 at 11:38 AM Reply With Quote
My x-flow came from an automatic car - it didn't have a spigot bearing, but did have a steel cup press-fitted over the end of the crank.
blakep82
posted on 9/7/09 at 11:43 AM Reply With Quote
why don't FWD cars have a spigot bearing?
________________________
adithorp
posted on 9/7/09 at 12:02 PM Reply With Quote
Don't bash it too hard. I've seen it done that the outer casing folds over a bit and binds on the needles.
adrian
ps. thats not the spigot that missing, it's the spigot bearing. The spigot shaft is the shaft coming out of the gearbox with splines to engage the clutch plate...just so we're all talking about the same thing.
fatbaldbloke
posted on 9/7/09 at 01:07 PM Reply With Quote
You can get them mail order from Burton Power as well.
