westf27
posted on 12/7/09 at 10:47 AM |
Pedal box alteration / replacement
My 2L pinto and type nine gearbox runs with the conventional cable clutch.Originally I fitted a vauxhall nova pedal box complete which went in the
narrow chassis F27 quite well,despite the overall width of the footwell being snug to say the least.My clutch cable goes straight out to the front of
the engine and gently curves round the headers by the alternator bracket,under and through to the clutch.I have heat insulated the cable after a
meltdown at Newlands one weekend.I want to create a light clutch operation (knee problems) and wonder what can be done.Forget hydraulic,will stay with
cable.Flood me with ideas for a solution please,in particular setups that have well for you.Suppliers/parts used would be usefull.
Good luck Lewis.....go boy
555
Gazeddy
posted on 12/7/09 at 11:30 AM |
either move the pivot or move where the cable is connected
posted on 12/7/09 at 11:33 AM |
Do you need to keep a hung pedal box rather than a floor mounted ? I have a floor mounted pedal box in my car using a cable which is pretty light to
operate.
westf27
posted on 12/7/09 at 11:54 AM |
Dont have to keep anything really.Happy to change anything to achieve light clutch operation with cable.I am assuming your cable does a 180 from pedal
box exit to clutch arm
555
gregs
posted on 12/7/09 at 02:40 PM |
why is hydraulic out of the question? - not as difficult as it might seem, especially if you use a pull cylinder (rally design), designed to replace
the cable... just my thoughts...
westf27
posted on 12/7/09 at 03:13 PM |
I thought hydraulic option would be expensive and a lot of work.Will check into the rally design option...thanks to those who replied.
555
lsdweb
posted on 12/7/09 at 05:45 PM |
Pullrod?
Easy to do and cheap!
