Author: Subject: After MotaLeira.....what next?
nitram38
posted on 15/7/09 at 08:24 AM Reply With Quote
Now the MotaLeira is built, my mind is wandering towards another build.
I have a few ideas, but whatever it is, it will probably be busa, possibly turbo.
The main thing is that I have a "wet" car..........something that I can use on rainy days too.
My skills in bodywork are ok but I find it laborious making moulds etc so this will not be a quick project.
To keep the car light I am considering canopy type screens, possibly from gliders, but I am finding them difficult to source. Any ideas where to get them?
Anyway, don't hold your breath on this one as I'm just at the ideas stage for now.
Martin
chrsgrain
posted on 15/7/09 at 08:29 AM Reply With Quote
These people will be able to get you a canopy, not sure it would be what you need though, as wipers would be difficult to fix....
Chris
pewe
posted on 15/7/09 at 08:32 AM Reply With Quote
A well deserved break.... but on second thoughts maybe not.... how else are the rest of us to keep ourselves occupied other than to follow all the twists and turns of your build?
Cheers, Pewe
nitram38
posted on 15/7/09 at 08:33 AM Reply With Quote
Thanks for the link.
There are other ways to shift water other than wipers.
Ships and Go-karters use a spinning disc to throw the water off.
[Edited on 15/7/2009 by nitram38]
Hammerhead
posted on 15/7/09 at 08:43 AM Reply With Quote
Caparo T1 replica?
Guinness
posted on 15/7/09 at 08:45 AM Reply With Quote
I'd be looking at re-engineering an existing body shell if I was you. Getting a new body shape right / then form the buck / then make the moulds / then take the panels sounds like an awful lot of work. (Hats off to the lads on here who are / have managed it!)
There was someone on here fitting an Elan bodyshell to an Indy chassis.
So think fibreglass bodywork / with a spaceframe chassis and busa turbo power. Early TVR / Lotus / etc?
Mike
nitram38
Originally posted by Hammerhead
Caparo T1 replica?
No, I want to do something different.
Guinness
posted on 15/7/09 at 08:46 AM Reply With Quote
Caparo T1 replica?
Oi, that's my coffee break dream!
Using an Audi V6 mounted in the back, complete with the gearbox is my pipe dream!
Mike
chrsgrain
posted on 15/7/09 at 08:51 AM Reply With Quote
Having spent a few years at sea, most ships have gone back to wipers as the spinning disk things (usually a wiper which just goes round and round rather than back and forth) are a bit rubbish! How about some high pressure air blowing the rain away??? Bit like a Dyson hand dryer....
Chris
[Edited on 15/7/09 by chrsgrain]
cloudy
posted on 15/7/09 at 10:07 AM Reply With Quote
locost plane... or is that my idea....
www.warnercars.com
Mr Whippy
posted on 15/7/09 at 10:18 AM Reply With Quote
If you want a canopy like used in gliders but need a flat laminated section in it for the SVA and wipers, then why not modify a glider one as they were on the mustangs. Also look up blowing canopy’s you'll see it’s actually a doddle to do, requiring little in the way of equipment and no mold is needed either except the window frame
or even the little bubble cars had a version if not very good looking...
[Edited on 15/7/09 by Mr Whippy]
tegwin
posted on 15/7/09 at 10:35 AM Reply With Quote
THAT... with a busa turbo in it!!!!!!!!!
[Edited on 15/7/09 by tegwin]
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 15/7/09 at 10:37 AM Reply With Quote
DIY blowmoulding canopies
how to linky
t.j.
posted on 15/7/09 at 11:26 AM Reply With Quote
Visit every one which is on locostbuilders.
That'll keep you busy
BTW: or help me
nitram38
posted on 15/7/09 at 01:53 PM Reply With Quote
The trouble with wipers on acryilic is scratching, but the possibilty of a flat section of glass is interesting, although a bit ugly.
What do gliders do in the rain?
There is always IVA without a screen.
For a wider car, there is always an Ultima windscreen, but how much!!!!!!
JC
posted on 15/7/09 at 03:23 PM Reply With Quote
How about the 'stealth' look? Lots of flat panels for the body - easier to fabricate?
http://imcdb.org/vehicle_214162-Custom-Made-Stealth-1993.html
nitram38
posted on 15/7/09 at 04:02 PM Reply With Quote
It might be easier, but boy is it FUGLY!!!!!!!!!!!!!
Dangle_kt
posted on 15/7/09 at 04:24 PM Reply With Quote
Why not stick to what your good at and work with an exist design? I give you......
Amitlu RTG
Its fully covered...
nitram38
posted on 15/7/09 at 05:38 PM Reply With Quote
The design of the Motaleira with an R1 plus extra panel weight, would spoil it.
A new design where the body forms part of the strength of the overall chassis would mean lighter chassis and still low power to weight.
Also a busa would mean re-designing the Motaleira rear chassis.
I'd rather have a car to play with while I am creating the other.
I did the same when I had the F1-2 and built the MotaLeira.
Bob C
posted on 17/7/09 at 11:10 AM Reply With Quote
here is some reasonable DIY canopy blow moulding info.
http://www.bhpc.org.uk/bubble-and-squeak.aspx
more if you google "furze platt greenpower" & follow links as to how they made "turbo toroise"
ZEN
posted on 17/7/09 at 02:58 PM Reply With Quote
Is this different enough?
OSI Bisiluro Silver Fox
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
speedyxjs
posted on 17/7/09 at 04:28 PM Reply With Quote
Is that amphibious?
