Author: Subject: Whats the name for this terminal ?
big_wasa
posted on 20/7/09 at 04:51 PM Reply With Quote
Whats the name for the crimp connector in the pic please.
Used in the prem wiring looms ect.
cheers
Confused but excited.
posted on 20/7/09 at 04:52 PM Reply With Quote
Picture a bit unfocussed, but if it is circular, as it looks, then it is called a bullet connector.
Edited to say: Have a look in the Vehicle Wiring Products catalogue.
[Edited on 20/7/09 by Confused but excited.]
Macbeast
posted on 20/7/09 at 04:59 PM Reply With Quote
Could also be a scotchlock (I think )
posted on 20/7/09 at 05:00 PM Reply With Quote
May be a bullet connector - but may also be a unsheathed spade connector... picture not clear.
Mark G
posted on 20/7/09 at 05:07 PM Reply With Quote
I know what it is But I'm affraid I don't know what its called, I do know that its none of the above though.
It doesn't plug into anything, it's to connect multiple wires together for feeds or earths.
Sorry I can't be any more help.
posted on 20/7/09 at 05:11 PM Reply With Quote
If that's the case, they are called a 'screw-it', as they screw onto the bared ends of the wires that are twisted together.
big_wasa
yep looked in vwp and there not in there.
Its for joining wires together ie a common live.
There is a metal crimp with a plastic mushroom on top
les g
posted on 20/7/09 at 05:27 PM Reply With Quote
Warren
you are right they are joining multiple wires together earth,s or lives or even can be used to insulate a live end
we cheat in work and make them ourselves by using a small bit of brake pipe and insulating with heat shrink
hows that for locost
cheers les g
Myke 2463
posted on 20/7/09 at 05:29 PM Reply With Quote
VWP page 21 Closed end connector / white ref.BCE 10= £1.00 + vat.
MIke.
big_wasa
posted on 20/7/09 at 05:36 PM Reply With Quote
Found them thanks for the help
big_wasa
posted on 20/7/09 at 05:37 PM Reply With Quote
Hows the build going Les ?
les g
posted on 20/7/09 at 08:41 PM Reply With Quote
Hi warren
got a few hours in on the build this weekend
got me wishbones etc so gonna have a bit of a push now the overtime is tailing off again hows yours coming on ?
posted some picture on haynes forum in bodywork section tital trial fit have a look and tell what you think
cheers les g
