Author: Subject: metal cutter recommendations
omega0684
posted on 24/7/09 at 10:21 AM Reply With Quote
morning guys
i have no idea where to start on this one, im looking for a metal cutter, for cutting box section accuretly etc at different angles?
what do i need to be looking for, price, makes models, reliability, quality etc
cheers
Alex
Mr Whippy
posted on 24/7/09 at 10:32 AM Reply With Quote
all depends on how much your cutting and from that what you are prepared to spend. If its not much then I'd use a disk saw, if loads then a band saw
dinosaurjuice
posted on 24/7/09 at 10:33 AM Reply With Quote
a metal cutting bandsaw is the best.
but they cost about £230
i would look out for a second hand one, i doubt youll regret buying it after using it a few times.
scottc
posted on 24/7/09 at 10:37 AM Reply With Quote
hacksaw and some spinach
http://www.sotoconnect.com
Mr Whippy
posted on 24/7/09 at 10:39 AM Reply With Quote
At least with the band saw you can use coolant and there's no sparks, it’s also far quieter
But you do need to check on blade availability as you can bet it will snap when the shops shut. I broke the work one several times out of carelessness or forcing it to cut to quickly. You also need to check the teeth spacing is correct for what your cutting, you need at least a couple over the cutting area, if the spacing is more than the area your cutting then the teeth will usually chip or the machine will stick when starting up.
flak monkey
posted on 24/7/09 at 10:51 AM Reply With Quote
Either a metal cutting bandsaw or a power hacksaw is the way to do it if you are lazy.
Otherwise just use a hacksaw you lazy git
Sera
http://www.motosera.com
iank
posted on 24/7/09 at 10:54 AM Reply With Quote
Good solid hacksaw handle, high quality bi-metal blades of the right pitch and some cutting lubricant. The time it takes to cut inch tube pales into insignificance in the scheme of things and hacksawing straight is a skill that's with you forever.
or a bandsaw depending on budget and space you have available.
Cheap and nasty hacksaw handles and blades from the local pound shop are no good. I've never got on with chop saws either as the good ones take a long time to set up and the cheap 'hinge for an angle grinder' ones are a waste of time, space and the material you'll waste. They're also noise and dirty things.
Get a decent bench linisher to finish up the tube ends, and/or learn to file accurately
Anonymous
Volvorsport
posted on 24/7/09 at 10:58 AM Reply With Quote
rage mitre saw .
www.dbsmotorsport.co.uk
getting dirty under a bus
r1_pete
posted on 24/7/09 at 11:44 AM Reply With Quote
Hacksaw and build a barmaid's, sorry barperson's bicep!!
designer
posted on 24/7/09 at 11:46 AM Reply With Quote
Ditto - Rage mitre saw.
Along with Machine Mart disc sander to finish off ends at whatever angle.
http://www.machinemart.co.uk/shop/product/details/cds300-300mm-disc-sander
posted on 24/7/09 at 03:41 PM Reply With Quote
Get your deaf aid ready when you use the Rage mitre saw, that is a good way to annoy the neighbours.
MikeR
posted on 24/7/09 at 05:29 PM Reply With Quote
I did mine the old fashioned way - hacksaw.
Its possible but you get a bit pee'd off eventually. I'd like one of those toothed cutting saws. They don't spin that fast so don't make that much noise. Do good, repeatable cuts .... just wish they where cheaper
907
posted on 24/7/09 at 07:49 PM Reply With Quote
Another vote for a band saw.
A saw is only as good as the blade.
Although twice the price a bi-metal blade does last ten times longer.
Paul G
eccsmk
posted on 25/7/09 at 12:23 AM Reply With Quote
i used a hacksaw for all my cutting etc
infact we've build 3 race chassis and apart from the odd dodgy blade never felt the need to get a band saw or the like
