tomgregory2000
posted on 26/7/09 at 01:18 PM |
Another brake question (sorry)
Is it better to have equal size pistons on 4 pot's or is it better to have 2 small pistons and 2 larger ones?
Cousin Cleotis
posted on 26/7/09 at 02:10 PM |
Unequal for even pad wear, but if the pads are quite short it wont make much difference.
What options have you got? What calipers are they?
Paul
posted on 26/7/09 at 02:39 PM |
Very strange calipers -- no very very bad idea the pads will wear tapered and cause a very spongey pedal
I have seen calipers with one large piston on one side facing and two small piston (ie total effective area on each side were equal) but this was
a production car Girling caliper back circa 1968 fitte to the Austin 1800S, Austin 3 Kires and MK1 XJ6
[Edited on 26/7/09 by britishtrident]
tomgregory2000
posted on 26/7/09 at 03:26 PM |
i ment the front(top) 2 pistons one size and the back(bottom) 2 pistons a different size
posted on 26/7/09 at 03:32 PM |
No that won't work the unbalanced force will just try and bend the disc and mounting bracket --- hydraulic area has to be equal.
bram boekestein
posted on 26/7/09 at 03:39 PM |
Yes it will, because equal size pistons will be opposite off each other. All 6pot's have a big leading piston and 2 small pistons trailing.
Like this(big piston needs to be on top):
