Paul (Notts)
posted on 26/7/09 at 09:51 PM |
What size / make throttle bodies RV8
OK…getting outside of my comfort zone hear but making the leap into the modern era with fuel injection.
The thor manifold on the rover v8 runs a single throttle body of 68mm.
The plan is to switch two duel throttle bodies ( one for each side) to help with bonnet clearance.
What size / make throttle bodies may work…?
Pics may help explain what I plan as Its getting late and I have had a few drinks.
[Edited on 26/7/09 by Paul (Notts)]
![](/galpreviews/a990358-13_horns.jpg) ![Rescued attachment 13_horns.jpg](/gallery/a990358-13_horns.jpg) Rescued attachment 13_horns.jpg
Paul (Notts)
posted on 26/7/09 at 09:52 PM |
original single throttle body
![](/galpreviews/a990360-je_thor1.jpg) ![Rescued attachment je_thor1.jpg](/gallery/a990360-je_thor1.jpg) Rescued attachment je_thor1.jpg
Chippy
posted on 26/7/09 at 10:39 PM |
The engine fills one cylinder at a time, and needs 68mm to do this, so think that it will need 68mm on both inlets. May not be correct, but seems
logical, (at least to me). Cheers Ray
stevebubs
posted on 26/7/09 at 11:39 PM |
According to this calculator, and only changing the number of bores & diameter, about 48mm on 2 bores gives the same sort of readings as a 68mm on
1 bore on a 3.8litre engine...
http://www.revtronix.com/techinfo/calculators/throttlebody.php
[Edited on 26/7/09 by stevebubs]
Toltec
posted on 27/7/09 at 10:23 AM |
Did you get that picture from http://www.mez.co.uk/ms12.html ?
Have you read the comments from Jonathan Douglas about the Thor manifold?
will121
posted on 27/7/09 at 11:56 AM |
the other thing i was thinking about was where were you thinking of mounting them? if close/on to the existing flange shown, wondering if the throttle
butterfly will shield airflow to the first inlet header?
Paul (Notts)
posted on 27/7/09 at 01:34 PM |
I know the Thor manifold does not yield as much BHP at high revs as the older version, BUT its better at low revs eg 1000 - 4000rpm. + not looking for
more that 200bhp from the set up.
Paul
