omega0684
posted on 27/7/09 at 09:57 AM |
Absolutely BRILLIANT Duratec engine video
for those of you like me who don't have an automotive engineering degree or years and years of engine building experience and are learning about
engines as you go along, like i am, i found this video whilst doing some googling about the Duratec engine.
i think that its a brilliant video and shows you how the engine is put together and it has an animation of the engine running. its a little blurry but
withstandable
Watch it on youtube here
fantastic stuff!
[Edited on 27/7/09 by omega0684]
Toltec
posted on 27/7/09 at 10:10 AM |
Enjoyed that , thanks, I played 'name the part' as it was assembled. Not totally sure I got the air con and pas pumps the right way
around. There is also a unit that went onto the lower, mid intake side that I did not recognise.
speedyxjs
posted on 27/7/09 at 10:36 AM |
Looks cool
Will have to watch it properly when i get home and have sound
matt_claydon
posted on 27/7/09 at 10:39 AM |
If this is the video I think it is, you will notice that one of the pulley bolts screws in anticlockwise as it is a LH thread - great attention to
detail.
Edit: same video but this version is too blurry to see the bolts screw in. Google "Deutz screensaver" for the HQ version as a
screensaver.
[Edited on 27/7/09 by matt_claydon]
Agriv8
posted on 27/7/09 at 11:24 AM |
suspect but not sure that it could be oil pump ? would have to watch it again
regards
Agriv8
James
posted on 27/7/09 at 11:43 AM |
That's soooo 2005!
That was all over the computers when I worked at Mclaren!!!
As Matt says, get the high quality screensaver (Deutz engine) version... you can see loads more.
Cheers.
James
- Muhammad Ali
Toltec
posted on 27/7/09 at 01:54 PM |
regards
Agriv8
I thought the oil pump was the chain driven part that goes into the lower front intake side.
Toltec
posted on 27/7/09 at 03:11 PM |
regards
Agriv8
I think the oil pump is the chain driven item on the front lower inlet side.
flak monkey
posted on 27/7/09 at 03:28 PM |
Theres a bit of an error in that as I dont think you can put the headbolts in once the cams are in.
Sera
http://www.motosera.com
