jpindy3
posted on 27/7/09 at 08:19 PM |
what amp wire for my fuel pump
what amp wire should i use for my fuel pump,i think it needs to be a bit hefty,would 8amp be ok
sorry i should have posted this in the right furom,my bad
[Edited on 27/7/09 by jpindy3]
omega0684
posted on 27/7/09 at 08:24 PM |
i run 10 amp, with 10 amp fuse
flak monkey
posted on 27/7/09 at 08:27 PM |
Use 1mm^2 cable which is rated to 16A
Fuse it 10amps
Sera
http://www.motosera.com
jpindy3
posted on 27/7/09 at 08:29 PM |
okey doky
Dave Bailey
posted on 27/7/09 at 09:59 PM |
I agree 16A fused @ 10A. The run is quite long and you need to avoid volt drop down the cable. I initially had 10 amp and after a short while the
cable was warm to the touch drawing about 7-8 amp.
Dave B
yellow melos
posted on 28/7/09 at 06:23 AM |
I did a test on my 72psi pump and it ran at just under 4 amps on all loads, normally the mump will comes with wires, how thick are they ????
Personally i would run 10 amp wire with 8 amp fuse....
but thats just me... it wont cause any problems using thicker wire.
