Guinness
posted on 29/7/09 at 10:06 AM |
Any electricians in the house?
I'm having a new Salamander Shower Pump installed on Monday.
It's going in the airing cupboard in the existing bathroom, but supplying the new ensuite in the attic.
Being in the airing cupboard in the existing bathroom means there isn't much electricity nearby!
I think I have four options:-
1. Take a fused spur off the lighting circuit in the bathroom. The pump is only rated at 2.4 amps. Easiest, but potentially dodgy.
2. Take a fused spur off the supply to the electric shower in the bathroom. Shower is on it's own 32amp breaker. Easy ish, but not sure if
I'd be allowed.
3. Take a spur from the existing ring main in either the attic or first floor. Will mean a fair bit of cabling through walls / ceilings / lifting a
few floor boards.
4. Take a dedicated spur from one of the spare ways in the existing DB in the understairs cupboard on the ground floor. Will mean major disturbance in
the force.
Am I allowed to put a fused spur in the airing cupboard in a bathroom? Or does the pump need to be wired back outside the bathroom? The central
heating pump is already in the airing cupboard, but the supply to that is switched via the c/h controls on the ground floor.
Mike
t16turbotone
posted on 29/7/09 at 10:13 AM |
hello, firstly please do not connect to lighting circuit! yes you are allowed to put new switched spur box in airing cupboard. just spur off upstairs
sockets- please make sure that this circuit is rcd protected
wilkingj
posted on 29/7/09 at 11:05 AM |
I think you may need to get it tested and certified by a correctly qualified electrician.
Consider it like car insurance.
If the house burns down and its proved to be your wiring (not correctly done - electrically wise) they could refuse to pay out. You know what
insurance companies are like.
I know that the rules for all wiring changed a couple of years ago.
I agree... Dont run it off the lighting circuit.
What ever you do.... do it properly.
Best Regards
Geoff
http://www.v8viento.co.uk
Vindi_andy
posted on 29/7/09 at 11:39 AM |
You can spur off the back of an existing socket which is on your ring main circuit. But it should be run off an RCD. there are 2 way to achieve
this.
1. RCD protection of ring main in main board (this may already be in place in not fairly easy and relatively cheap to do.
2. buy an RCD protected outlet.
As it is a spur you won't need it checking off.
This is coming from my colleague who is 17th edition and part P qualified.
SteveWalker
posted on 29/7/09 at 11:59 AM |
I'm not 100% sure how restrictive things are, but both bathrooms and kitchens are now deemed special locations and almost any electrical work in
them requires either a building notice or a registered electrician.
Personally, I'd be tempted to look for some red and black twin and earth, wire it myself (safely) and pretend that it had been in from before
the rules changed!
s2gse
posted on 29/7/09 at 12:02 PM |
option 3 would be best and install an 30ma RCD 13amp fused spur with 5 amp fuse
all equipment within a bathroom should be protected by an RCD
life's to short and so was the drive
posted on 29/7/09 at 05:03 PM |
hi mike! Dont worry about part P, i know plenty of sparks who didnt get registered and actually trade with no ticket, and dont get caught. Im sure you
know how to wire it to the regs so just DIY. Wire colour also isnt important as there was a 3 month overlap before fart P came in.
Sticking my neck into the firing line, you can connect it to anything you like so long as you know how to prove you designed it properly. Ie just
because its called a shower circuit doesnt mean you cant change it to a 'shower and pump' circuit, with correct fusing of course.
