Author: Subject: Would this relay stop sparking?
leemarkadams
posted on 30/7/09 at 07:09 PM Reply With Quote
Hello all, the relay highlighted in the picture appears to be faulty, so would that stop the engine sparking but allow the starter to turn?
If so, can it be bypassed to test and see the engine will spark?
Lee
MautoK
posted on 30/7/09 at 07:56 PM Reply With Quote
There's a blue/white wire second left from the relay assembly to a link in the starter relay then a red/white on to the ignition control unit. I'd be checking continuity and voltage along there.
Also possibly worth checking out the kill switch.
Just my .02c as a non-BECist.
John.
MautoK
posted on 30/7/09 at 07:57 PM Reply With Quote
Edit: oops, no, that's the starter relay coil
John.
dan__wright
posted on 30/7/09 at 08:34 PM Reply With Quote
i took the relay box out on my zx10r (bypassed so everything still had continuity) and it wouldn't star - no spark, put it back in and it started straight up first time
FREE THE ROADSTER ONE…!!
Eggy
posted on 30/7/09 at 08:36 PM Reply With Quote
Check that there's 12v on the red/ black on the stick coils.
Have you linked out the side stand and clutch switches?
mackei23b
posted on 30/7/09 at 08:58 PM Reply With Quote
That will only control the fuel pump.
Ian
rgrs
Yes is the short answer, that unit contains 2 relays and the double diode system used to detect the clutch switch/ side stand .
From your previous posts i seem to remember that the fuel pump wasn't running either.
put a neg onto the light blue wire 4th from right and see if it runs.
if it does then issue with clutch switch/ side stand switch
check also that you have 12v on the red/black 1st from left, with the ignition on you should have a permanent feed.
regards Roger
zetechamo
Try putting a temp 12v supply on to red/black wire on coils and then try to start, if it runs then the relay is faulty
leemarkadams
posted on 30/7/09 at 09:04 PM Reply With Quote
Thanks for the replys, any ideas where I could get a replacement relay from?
Lee
Eggy
posted on 30/7/09 at 09:25 PM Reply With Quote
Isn't it part of the fuse box?
speed8
posted on 30/7/09 at 11:39 PM Reply With Quote
Yes, it can stop you from sparking. I had a bad one for an 03 R1. If you need one try Malc at Yorkshire Engines, he might be the cheapest and quickest way of getting a spare.
Do you have the cyclelock? If so, are you sure you have sorted it all out properly? I had one wire that I hadn't run to ground and it caused me a whole heap of bother. If you don't have cyclelock then its not an issue.
If that diagram is what you have then it definately seems cyclelock related. I would be comparing the diagram with non cyclelock and seeing where the black wires out of the relay go to.
ETA: Just seen your other posts in that it had been running on a track day.
Tilt switch (the 03 has, don't know about 99). Kill switch, but if the pump runs then you are getting power to the relay.
[Edited on 30/7/2009 by speed8]
adithorp
posted on 31/7/09 at 07:34 AM Reply With Quote
I don't think it could stop the spark; just the starter and fuel pump. Have you checked continuity from the relay?
I'd look at...
Wiring connectors. Has it got an FIA battery cut-off? If so are all the low tension wires still on?
Have you checked to connectors to the ignition switch?
Someone recently had very similar symptons on here and it turned out to be a loose wire.
Is there a hidden security switch or immobiliser fitted somewhere that could have been accidentally turned off?
Tilt switch is only on injection engines I think, so shouldn't effect your engine. It does kill ignition and pump but not starter though.
Kill switch (if fitted and not by-passed) should stop the starter operating.
adrian
[Edited on 31/7/09 by adithorp]
http://jpsc.org.uk/forum/
leemarkadams
posted on 31/7/09 at 07:42 AM Reply With Quote
Just to clarify, the fuel pump does not work via the relay as I can get if to work by running a direct feed to the pump( new pump).
Have nit seen a kill switch as it runs off sierra column and key.
Is there any way to temporarily bypass the relay?
lee
adithorp
posted on 31/7/09 at 08:42 AM Reply With Quote
Have you got 12v at the red/black wire going into the relay and the red/black into the coils when cranking?
adrian
leemarkadams
posted on 31/7/09 at 10:48 AM Reply With Quote
adrian
Yes I have 12v at the red/black wires, bith at coils and relay.
Lee
leemarkadams
posted on 31/7/09 at 12:09 PM Reply With Quote
Right, just been through all the tests in the service manual and all seem ok, except this relay which failed. I will order one from Malc (who I spoke to this morning and said this relay failing can cause the spark to not work) on Monday and see what happens. I just don't undersatnd what else it could be?
If still not working then I guess I will have to get a pro in to have a look!
I will re-wire it all in the winter, but want to enjoy it during the summer if possible, and another track day in September
Thanks for all the help and anyone think of anything else at all, I thought of the cyclelock thingy but have not touched any of the wires except the relay and ICU ones, and that is only to test them!
Lee
adithorp
posted on 31/7/09 at 12:38 PM Reply With Quote
Have you got 12v out of the relay on the blue/red wire (going to ECU) when cranking?
leemarkadams
posted on 31/7/09 at 01:32 PM Reply With Quote
Yes I have, as just tested it.
Lee
mad-butcher
posted on 31/7/09 at 05:38 PM Reply With Quote
Hi Lee
I know it's frustrating, but if the car worked untill the pump/relay packed up, wait untill you get a new relay before you start changing too many perameters in your search. if you were anywere on the wirral you could have borrowed my relay and pump
tony
leemarkadams
posted on 31/7/09 at 06:21 PM Reply With Quote
Originally posted by mad-butcher
Hi Lee
tony
Thanks, that is the plan at the moment, am away next week anyway so will have a replacement relay by then and see how I get on.
I guess am just a little impatient!
Lee
