FASTdan
posted on 5/8/09 at 07:10 AM |
sierra gearbox, strong enough for 2.3 Duratec?
Currently we're running a 2.0 pinto, RR'd at 110bhp@ wheels on the standard gearbox as out of the 2.0 injection sierra - is this a type 9?
I'm not up on the gearbox names.
We've got plans for a 2.3 duratec on bike carbs (ZX9R) which I'd hope would be around 200bhp at the fly? What sort of power will the
gearbox take (assuming good condition of course)? If its not going to be any good, whats the options for upgrading?
I was kind of hoping fords safety factors would be similar to that of the CVH gearbox, which seems to handle anything up to 200bhp and masses of
torque from an RST.
mookaloid
posted on 5/8/09 at 07:20 AM |
Should be ok but if it isn't, you'll have to upgrade it
The V6 box with the long input shaft is stronger and better - it has a higher first gear so that might be a better choice to start with.
mcerd1
posted on 5/8/09 at 07:49 AM |
have a look at the BGH boxes linky
FASTdan
posted on 5/8/09 at 08:38 AM |
I know someone breaking an XR4x4 - would the box out of this be adaptable to be 2wd?
mookaloid
posted on 5/8/09 at 10:29 AM |
I believe this has been done but I don't know much about it.
Mark
mcerd1
posted on 5/8/09 at 10:43 AM |
BGH might just exchange it for a 2wd one, if you give them a call they'll tell you what your options are
I got one of there E8 boxes second hand, and they've been very helpful at answering all my questions so far
[Edited on 5/8/09 by mcerd1]
repper
posted on 5/8/09 at 01:10 PM |
ford borgwaner T5 fitted in 2WD cosworth and mustang good up to 500 hp + strate out off box with no mods
![](/galpreviews/) ![](/gallery/)
Trev Borg
posted on 5/8/09 at 01:18 PM |
The T5 box would be the one to go for imo, but the type 9 attached to Owelly's alfa V6 has not broke yet, and its had loads of abuse.
The diffs have failed , but the type 9 has been fine.
The are supposed to be good for 150bhp, but kitcars are light, and there is not as much strain put on them.
I had a long shafted type 9, but it was badly worn.
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
snapper
posted on 5/8/09 at 05:38 PM |
The T5 box also has much better 1st gear ratio 2.92 to 1 and they are available from £300 you will need a Rally design (or similar) bellhousing to fit
the box to a Duratec.
A V6 Type 9 will need the bellhousing and possibly the Caterham bellhousing spacer @ £100
An uprated BGH box will be around £500 close to £700 with the 2.8 1st gear set
I eat to survive
I drink to forget
jpindy3
posted on 5/8/09 at 07:09 PM |
matethe t9 will easy take that power as long its in good nic,the pinto turbo boys are putting 250-280hp through them and they are dealing with it for
longer than you would expect.im going to put 270hp through mine.
FASTdan
posted on 7/8/09 at 06:51 AM |
Cheers for the input guys. sounds like it'd do the job for a while anyway so we'll probably just stick with it for the time being and
upgrade if/when it does let go.
