mad4x4
posted on 5/8/09 at 12:02 PM |
Injection or Carbs
After driving a 1.8 Zetec Focus (t Reg) got me thinking my Indy doen;t pull that well on Bike carbs....
so what is best for a quick car on a budget for road use with ocassional track.
Currently car is
MK Indy
Stock 1.8 Zetec with GSXR750 Carbs and MegaJolt
[Edited on 5/808/09 by mad4x4]
Scot's do it better in Kilts.
blakep82
posted on 5/8/09 at 12:05 PM |
hmm, i'd be thinking about rolling roading it if you haven't already. no reason why it shouldn't pull as well as a standard focus
________________________
twybrow
posted on 5/8/09 at 12:06 PM |
Bike ITBs and Megasquirt. Been done a thousand times, so lots on info out there.... I wouldn't think it would make as big a difference as
possibly you are hoping for. Have you had your current setup properly sorted?
Mr Whippy
For a budget job I just fit a stock setup of a scrap car, if you can squeeze it all in
omega0684
posted on 5/8/09 at 12:11 PM |
this is a good setup to have, i've got it and even the BEC owner i went out with the other day was surprised how well i was keeping up!
other options
1) stick a turbo on it
2) put 2.0 zetec cams and then go Bike ITB's & Megasquirt!
[Edited on 5/8/09 by omega0684]
adithorp
posted on 5/8/09 at 12:22 PM |
R1 throttle bodies attached to an R1...
...now where's the popcorn!
adrian
http://jpsc.org.uk/forum/
r1_pete
posted on 5/8/09 at 12:35 PM |
Bike ITB's, wish I'd done it from the outset rather than spending a fortune on Boggs and bike carbs.....
Its not as complicated as it first looked.
twybrow
posted on 5/8/09 at 01:26 PM |
quote: this is a good setup to have, i've got it and even the BEC owner i went out with the other day was surprised how well i was keeping
up!
Not quite how I put it, but if it makes you feel better....!
omega0684
posted on 5/8/09 at 02:25 PM |
up!
Don't Lie!
will121
posted on 5/8/09 at 05:20 PM |
Currently car is
MK Indy
(assuming silvertop?) one thing you dont say is what cams you are running? if standard 1800 zetec may only be putting out 115bhp, first thing i would
do may be a basic Rolling road run to check whats it putting out which is about £45, then (if not fitted) fit 130BHP cams from 1800RS fiesta or 130
Mondeo then with bike carbs should be about 140bhp ish if set up right on bike carbs
jpindy3
posted on 5/8/09 at 07:27 PM |
your better off changing the cams first,have a look for a good second hand pair.i really wouldnt bother going to the rr till you have done the cams at
least.then sick on the tbs and mj
austin man
posted on 5/8/09 at 09:23 PM |
im running a stock 1.8 from a mondeo with 2litre cams and twin 40's it pulls well enough an ST170 couldnt lose me up to 90 we then both backed
off. Sounds to me like its not set up properley.check the timing and take at for a blast then check the colour of the plugs to see how the mixture is
mad4x4
posted on 7/8/09 at 05:14 PM |
For Reference it has the 130 Cams in it it is an old red top zetec from an Auto Mondeo or Escort
mrwibble
posted on 7/8/09 at 09:09 PM |
what car is that 1.8 in?
FASTdan
posted on 8/8/09 at 08:36 AM |
No disrespect, but if your 600ish KG indy isnt pulling as well as a 1.8 focus then there's something seriously amiss.
Likewise, an ST 170 shouldnt be challenging any of the cars on here either??
Our pinto powered car (110@ wheels) will easily see off the above. I'd expect any 7 with a zetec and bike carbs to be quicker than ours.
flak monkey
posted on 8/8/09 at 08:40 AM |
Bike ITB's with megasquirt. Simple and cheap.
If you dont want the hassle of setting it up yourself you can always pay £1200 for a complete set up from one of the many companies offering bolt on
throttle body injection systems.
You will get better flexibility and economy with fuel injection too without losing any performance.
Sera
http://www.motosera.com
jedi
posted on 9/8/09 at 08:09 AM |
never had a problem with my bike carbs
